Estate Purchased VP2
dennisanderson
Post by dennisanderson »
I'm not sure this is the correct forum, but here goes...
I have a Vantage Vue that's been functioning beautifully for four years. I've wanted to get it online with WU, but the cost was prohibitive. I recently purchased a VP2 at an estate sale thinking I could use it to get online. Following is the information from the back of the unit:
IC: 3788A-6312
Mfg.Code: A50915A41
Model: 6163
Bar: NC
HUM: NC
Final Insp: HN
It also has a WeatherLink Data Logger installed.
It's communicating well with my instruments.
I'm considering using Meteobridge and flashing a TP-LINK TL-MR3040.
Re: Estate Purchased VP2
What type of WeatherLink Data Logger do you have (WLIP, Serial, USB?)
if WLIP then that will upload straight to WU, MB will also upload to WU and give you a lot of other/more options as well.
dennisanderson
The data logger has a USB connector.
USB logger can connect to WeatherLink Network but requires a yearly subscription etc.
Go the MB way, will be cheaper in the long run and much more flexible
