Indoor Temp sensor
warrenb
Indoor Temp sensor
Post by warrenb »
Hi there
Very new to this , but am looking to purchase a Red Pro. Just one question, if I use the inbuilt wireless pickup of data from the ISS, where would the pro get the indoor information from.
Also, I am thinking of using the email send to setup an IFTTT to control my heating for certain temperature ranges, anybody got any experience of doing this ?
Re: Indoor Temp sensor
MB PRO has its own internal temp/hum/baro sensor and makes use of it.
As the sensor is in the housing it is heated up against ambient temperature,
but you can add a negative offset to it to get it somehow leveled to room temperature.
warrenb
Post by warrenb »
Thank you
Unit ordered
warrenb
Post by warrenb »
All up and running, but I am getting lots of the following errors
database (11.05.2017 16:12:09): cannot commit RAM (after 100 tries in 9021ms): database is locked
database (11.05.2017 16:12:18): cannot insert into data10num_hour RAM (after 100 tries in 9151ms): database is locked
database (11.05.2017 16:12:18): rollback on insert forced (2) (min): data10num
database (11.05.2017 16:12:27): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (11.05.2017 16:12:36): cannot insert into data10num_hour RAM (after 100 tries in 9133ms): database is locked
database (11.05.2017 16:12:36): rollback on insert forced (2) (min): data10num
It does this continually
Any ideas ?
warrenb
Post by warrenb »
Thought I had fixed it, but alas no, does this look like a back internal USB.
Also is the display on the front supposed to be on all the time (setting in System is set to "Always On" as mine just comes on every now and again.
OK Also tried a front USB, and get the same error as above.
Re the front display check the comments in the attached link from April 22 on
http://www.meteobridge.com/wiki/index.php/Forum
Basically set to "Always on" in normal mode will display the screen for 3 seconds every minute, designed to reduce screen burn out.
warrenb
Post by warrenb »
Mattk wrote:Re the front display check the comments in the attached link from April 22 on
OK Cool, I have set it to rotating large font now anyway, this should also negate screen burn.
The database issue seems to have cleared itself up also. So all good.
