Non working RF **solved**
besty1967
Post by besty1967 »
I bought a meteobridge pro from Prodata in the UK to add to my Davis Vantage Vue. I'm able to connect and use it by usb but it wont do anything via RF. I've followed the advice on wiki and set it up as a RF strength meter but I'm not getting anything on it. I get the data section with'--' but no second section for the strength of RF signal. To me this sounds like a faulty box or aerial. It is set up for wifi network and internal rf receiver on ISS transmit station 1. The ISS is only about 35feet from the meteobridge pro next to the vue console. I have tried retransmitting the data from the console but still no signal strength is shown on the pro readout. The led for the rf only flashes when it first reboots and then only for a few times then nothing after that.
The wifi side of the box works fine for pc to pro communication but its only the rf side that is not working.
I have spoken to Prodata and they said I should post it on here and see what anyone can think of.
Hope someone has an idea as I can't do anything about changing the box with prodata till I've had some advice.
besty1967
Re: Non working RF
Post by besty1967 »
This is the message log for the last reboot done with the rf settings all applied, no mention of ISS or RF in any parts. Hope it helps.
oled (12.07.2017 13:11:41): process started.
database (12.07.2017 14:15:42): process started.
wnetd (12.07.2017 14:15:44): process started.
system (12.07.2017 13:15:44): start of logging process initiated.
logger (12.07.2017 14:15:45): databases connected. Update interval 3600 seconds.
logger (12.07.2017 14:15:45): historical data loaded (0 records).
logger (12.07.2017 14:15:45): data logger (version 5.0v, build 11296) started.
logger (12.07.2017 14:15:47): connect station 0 (Meteostick Vantage via USB serial).
logger (12.07.2017 14:15:47): connect station 9 (System Data via Plug-in).
logger (12.07.2017 14:15:50): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (12.07.2017 14:15:50): services paused.
database (12.07.2017 14:16:19): database sync done (36 tables, 448/1633 writes)
Re: Non working RF
You didn't specifically mention but I assume your Vue is an EU version and the MB RF is set to EU868?
besty1967
Re: Non working RF
Post by besty1967 »
Sorry yes that is correct, but I have tried on the US settings also, both sets of equipment were bought from the same outlet. I've set the MB rf to EU 868 and the station to #1 for the Vue ISS
Re: Non working RF
Try setting the RF Sens (Station tab) from the default (-90db) to around -80db Narrow and give it a good 5-10 minutes, Davis & MBPro can take a little while to sync up at times.
besty1967
Re: Non working RF
Post by besty1967 »
After your last email I did what was suggested and after about 1 hour I checked the MB. It still shows nothing, on the display on the front of the MB I'm not getting the dashed lines for the rf strength only the normal dashes where the outdoor sensors readings would be. This is the log after I did the recommended changes.
system (13.07.2017 07:53:34): stop of logging process initiated.
system (13.07.2017 07:53:39): stop of logging process initiated.
system (13.07.2017 07:53:40): start of logging process initiated.
logger (13.07.2017 07:53:40): databases connected. Update interval 3600 seconds.
logger (13.07.2017 07:53:40): historical data loaded (0 records).
logger (13.07.2017 07:53:40): data logger (version 5.0v, build 11296) started.
logger (13.07.2017 07:53:41): connect station 0 (Meteostick Vantage via USB serial).
logger (13.07.2017 07:53:41): connect station 9 (System Data via Plug-in).
logger (13.07.2017 07:53:44): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (13.07.2017 07:53:44): services paused.
logger (13.07.2017 07:55:41): give up waiting for sensors after 120 secs.
logger (13.07.2017 07:55:41): services activated.
logger (13.07.2017 08:54:11): child process received timeout signal (14).
logger (13.07.2017 08:54:11): disconnect station 0 (Meteostick Vantage): exit
Re: Non working RF
can you please setup remote login and send URL and password to "info(at)meteobridge.com".
I would like to have a look. RF should work fine, when configured correctly.
viewtopic.php?f=57&t=9885
besty1967
Re: Non working RF
Post by besty1967 »
I'm away from the PC this weekend, I will be able to do it Monday evening. How do I setup the remote? I found the link, I'll set up on Monday. Any particular time?
I've been able to get sorted today, have emailed the required things.
besty1967
Re: Non working RF
Post by besty1967 »
Brilliant service thanks for everything.
