I have a total of 7 stations I am using for different things - 1 wind, 1 ISS, 1 Solar/UV, 3 Soil. I've noticed that after I added about the 4th or 5th station to Meteobridge Pro, that the Datalogger is saying 8/10 times "Data logger momentarily cannot provide data. Please try again in a minute. If it does not show up later, please also check weather station selection on "Station" tab."
Also, some sensors will appear, then aren't getting picked up for long periods even though they are transmitting, and at a fair signal strength (-60 to -65 db) randomly (but rarely), then start working again - Meteobridge will say last transmit 10 minutes, 20 minutes, etc. then randomly like I said they start working again.
Any reason for this?
Issue with Datalogger dropouts
- dlogger.png (12.74 KiB) Viewed 5275 times
Re: Issue with Datalogger dropouts
looks like restarts of the data logging process, but I can be wrong.
When you give me a remote login I can check.
I changed settings to "-85db narrow" instead "-90db normal". Normal should only be used when data retransmitted from console is to be received.
Seemed to be OK for the evening but it's doing the same thing again off and on.
BTW, what's wide used for?
"wide" is just for "WS 1000" station. I will make the settings a bit more self-explanatory on next updates.
I'm still having the issue with the datalogger. 9.5/10 times I visit the Live Data page it just says "Data logger is unavailable", though it's sending data to services.
Can I login to check?
Sure anytime
Might want to try it several different times if it works - guarantee it wont more than does.
Any progress on this?
I'm noticing that it is infact dropping out randomly, and not reporting data to WU, CWOP, etc., then starts again.
Not an Internet issue because I have other things on 24/7.
I may have a strange setup with alot of Push services + a fully loaded network of 8 stations...
