Hi!
I have a WH4000 weather station.
The solar data is updated every 48 seconds on the WH's display. Unfortunately, the current value is not good in the MeteoBridge.
The station measures 1~350 w/m2 in this season, MB shows 0 or 32w/m2 or 175w/m2 in the "live data" window. Shows only 3 values.
Please help me.
Solar data problem - WH4000 **solved**
Kiskrampusz
- Fresh Boarder
- solar.jpg (169.26 KiB) Viewed 3647 times
- IMG_20171225_123626.jpg (132.86 KiB) Viewed 3647 times
Kiskrampusz
- Fresh Boarder
Re: Solar data problem - WH4000
Hi!
The Meteobridge reads the solar data incorrectly from WH4000 station. Currently 440 w/m2. But MB reads 175 w/m2.
Please help me!
Please help me!
Kiskrampusz
- Fresh Boarder
Hi!
I updated to the latest version (March 3). Now the solar data is updated, but the read data is 10 times larger.
For example:
Correct data on WH4000 display: 36.58 W/m2
Live Data on MB: 365.8 W/m2
Can you fix it?
For example:
Can you fix it?
Kiskrampusz
- Fresh Boarder
Hi!
Unfortunately, it doesn't work.
The UV value is bad (decimated).
The solar data is still bad (x10).
- Screenshot_2018-03-04-11-03-55.png (191.76 KiB) Viewed 3399 times
- Screenshot_2018-03-04-10-14-48.png (177.5 KiB) Viewed 3401 times
I fixed the UV index. But solar radiation should been fine already. Can you please try with todays update?
Kiskrampusz
- Fresh Boarder
Hi!
Solar radiation is OK, updated.
I will check the UV in sunny day. Probably tomorrow.
Thank You! I will back soon.
Kiskrampusz
- Fresh Boarder
Hi!
UV is OK.
Thank You!
UV is OK.
Thank You!
- Screenshot_2018-03-05-09-55-23.png (176.49 KiB) Viewed 3373 times
