backup on usb-stick **solved**
aeng2
Post by aeng2 »
How do i start a data backup by hand?
I insert a usb-stick 16gb (fat32) in the front connector and press backup. Then i get this message:
Not enought free space on media
Re: backup on usb-stick
That should work. If you give me a remote login, I can check why it does not do.
Please send URL and password to "info@meteobridge.com".
Inspection did show that the USB stick has a complex partition structure with three partitions at all. First one (which is used by Meteobridge for backup) was just 30 MB, so the error message is right. The stick needs some rework to provided a suitable first partition.
aeng2
Re: backup on usb-stick **solved**
Post by aeng2 »
problem was the usb-stick.
I did a low level format that remove hidden partitions.
Works oke now
