I switched back to the Internet Bridge from the Access and am not logging pressure data any longer.
Live Data
Sensor
Outdoor #5
Am running Meteobridge 3.5 (Jan 28 2018, build 11900), FW 1.3
My>Acurite reports pressure so the bridge is sending the data.
Any ideas. Thanks
Acurite Bridge pressure not being logged
Re: Acurite Bridge pressure not being logged
Can you please share the complete system messages log?
Sorry, I didn’t look at the log, just the live data. Obvious error —-
logger (01.02.2018 12:30:44): Bad thb0(0) sensor data, "sea level pressure x10" (13514) out of range [4000:13000]
The pressure correction is set to 0.000 inHg.
Bridge application version 224
Bridge boot f/w version 104
I reset the MeteoBridge and it picked up the “Indoor” sensor (pressure).
I also needed to set the bridge to “station pressure” to get the expected value.
With this configuration, My>Acurite is reading about 6 points low.
I think there is another thread addressing this situation.
The Acurite stations are know to be "creative" on pressure adjustment. I cannot recommend any Acurite station when you look for reliable pressure data.
