Poblem white the primaire sensor!
gdijkstra
Post by gdijkstra »
Meteobridge primaire sensor is th0temp but i want to have th1temp as my primaire sensor. But now i get the temperture of th1temp also in th0temp :oops: ? How can i solve this? HELP
Re: Poblem white the primaire sensor!
Go to [Live Data] tab, position mouse pointer over sensor th1temp, a box will pop up saying something like "Click to use th1temp as primary sensor"
gdijkstra
Post by gdijkstra »
Mattk wrote: Tue Aug 21, 2018 10:58 pm Go to [Live Data] tab, position mouse pointer over sensor th1temp, a box will pop up saying something like "Click to use th1temp as primary sensor"
That is what i did, but then i get de same value in th1temp en th0temp. The value from th1temp (this is the primary sensor).....
In which context do you get data from "th1temp" when asking for "th0temp"? When evaluating templates?
Please also read this release notes from March:
released March 10, 2018
adds template variable expressions "[mbsystem-primarysensors:]" and "[mbsystem-noprimarysensors:]" to control inside a template if "0" sensors (like th0, wind0, rain0, etc) should be replaced by sensors defined on "Live Data" tab as primary or taken literally. The mentioned template expressions are evaluated to the empty string and thereby do nothing directly in your template but control how variables are evaluated as a side effect.
Taken from https://www.meteobridge.com/wiki/index.php/Forum
gdijkstra
Post by gdijkstra »
The template is meteotemplate.com. In the api file i get the sensor value from th1temp also in th0temp?
