meteobridge TL-MR3020v3 **solved**
Leon
Post by Leon »
My meteobridge seems to be unable to communicate with my Davis vantage vue....
This started at 4 am this morning without any changes to anything.
I have rebooted without success.
Please see attached screen shots.
Any suggestions ?
Regards,
Leon Rossouw.
Screen Shot 2018-09-24 at 10.08.49.png (209.14 KiB) Viewed 3938 times
Screen Shot 2018-09-24 at 10.06.43.png (239.96 KiB) Viewed 3938 times
Screen Shot 2018-09-24 at 10.05.53.png (136.73 KiB) Viewed 3938 times
Re: meteobridge TL-BR30203020v3
  • Did you check the USB cable if it is properly seated?
    Disconnect and then firmly reconnect it on both ends.
  • Can you also post a screenshot of the "WeatherStation" tab?
Leon
Post by Leon »
Thank you for your prompt response...I am frustrated because station was working properly for months and currently I am not there.
I am logging in remotely.
Problem seems with communication between station and meteobridge.
I have not changed anything at all.
see attached screenshots
Regards,
Leon.
Screen Shot 2018-09-24 at 11.46.00.png (159.89 KiB) Viewed 3930 times
Screen Shot 2018-09-24 at 11.45.44.png (330.3 KiB) Viewed 3930 times
Leon wrote: Mon Sep 24, 2018 11:52 am Thank you for your prompt response...I am frustrated because station was working properly for months and currently I am not there.
Regards,
Leon.
Then the only thing you can do is "wait and see".
Most of the times, 80% or more, it is a simple cable problem, They become disconnected over time because of stress on the cable, temperature changes, cats or mice, a.s.o.
When it is a "device failure" it is probably the power or batteries of the console. Another 19%
Loggers or consoles itself nearly never fail
But you have to be there to inspect and find the cause.
I see you have the latest version (Sep 22, build 1145), did you update this specifically and do you normally run with Version Control set to "get newest on boot"?
Leon
Post by Leon »
I normally run script to reboot early morning and run version control to get latest firmware on reboot.
I have 4 meteobridge stations running and none of the others have problems...also running latest firmware.
The other meteobridges are TL 3020 version 1 and this one version 3 but it was running a whole 24 hrs without any problems on latest version firmware.
It is just weird because no-one touched it and has been running flawlessly for months.
I am only going to be able to physically check all later this week as I am currently away and logging in remotely.
I can always forward login details and passwords if you would like to remotely login yourself ?
Thank you,
Regards,
Leon.
Leon wrote: Mon Sep 24, 2018 12:45 pm I normally run script to reboot early morning and run version control to get latest firmware on reboot.
Thank you,
Regards,
Leon.
You also said in your first post
That is a little conflicting. So better do a manual reboot to a previous version, just to exclude the 0.1% chance that the problem is caused by the sep 22 version.
success, Wim
Yes would drop it back a version even thou the others have no issues as there is certainly a match with the reboot time and there is a difference in 3020 model versions
Leon
Post by Leon »
Thank you all.
I finally could physically check all today.
And yes Wim....it was the console batteries !!!!! :cry: :cry: :x :x
Sorry but I guess there is always a lesson to learn from everything :oops: :oops:
Regards,
Leon.
Re: meteobridge TL-MR3020v3 **solved**
Leon, So do you have no mains power or simply running the Vue on batteries only?
Leon
Post by Leon »
Helo Matt
I do have mains powerat this particular station but I am simply running the station console on batteries only.
It is due to my own negligence... :oops: :oops:
I just couldn't think that I would overlook such a simple issue :( :oops: :roll:
Regards,
Leon.
