Meteostick air pressure: Spikes, normalizeing
CFJH
Post by CFJH »
I'm running a meteostick to read the VP2 since 2017. It is read out from a Linux server with plain shell scripts.
Now, I,ve time to make some software for visualizing. But here I've currently two problems:
1. I've sporadic spikes in the pressure, see attached image LD001.png. The problem exists since 2007, but noticed only yet. The stick is connected with a 1m USB cable to the computer (was shipped with the stick). I've tried different positions and putting some ferrite cores on the USB-cable near the stick.
1.1 The firmware of the stick is 2.3b1. If a firmware update solves the problem, how can I do it (on a plain (opensuse) Linux system) ?
2. How can I normalize the pressure to NN. Currently I add an constant offset of 5.25 to the values (height is approx 60 meters). But this is not exactly correct, one time, the pressure is a little bit too high, at other time to low (see LD002.png).
Jürgen
CFJH
Re: Meteostick air pressure: Spikes, normalizeing
Post by CFJH »
No one has an idea or can give me a tip? :(
Jürgen
Is the stick in a room that has pressure variations (reminds me to blower door test, etc)?
CFJH
Post by CFJH »
the stick is in my normal study. Unless I open the door, there should be no pressure fluctuations. I also tried different locations for the stick again (which are accessible with the 1m long connection cable), no changes. The spikes are looking for in the night when nobody is in the room.
The firmware on the stick is version 2.3b1, so older. Could an update solve the problem? But my worry is, if this goes wrong and the stick doesn't work anymore.
Enclosed a current history graphic.
Jürgen
CFJH
Post by CFJH »
Hallo,
Now I've done a firmware update to the MS. But the spikes already persists.
But: I load'ed the firmware here from from the meteostick page:
The firmware is now 2.2, before it was 2.3b1
Is the firmware link out of date ? :?
Jürgen
CFJH
Post by CFJH »
No Idea's
No link to an actual firmware for the stick ?
What version number has the actual firmware ?
2.5.3 is the most recent one. Link has just been updated.
