No logging after update 26oct **solved**
svampen
Post by svampen »
I rebooted my Meteobridge yesterday, due to general work on my network settings.
Meteobridge Nano updated to the 26 october version.
I now notice that it only seems to update the current values. There is no history. Looking in "Live data" there is only "--" in the column of todays high/low on every sensor. My webpages look very awkward with only showing the webtags where todays high/low are suppose to be.
Here's a small page I use on a mobile phone, as an example:
https://home.krumelur.nu/vaderarkiv/console.html
Nothing out of the ordinary in the system log.
Tried soft reboot but no success.
Ideas? :(
Re: No logging after update 26oct
When you give me remote login, I can have a look.
leliep
Post by leliep »
Same problem for me. It happened initially with software version 4.0
The data stopped at the time of the 06:00h reboot on Oct 27th. Due to stability issues I do a reboot every 6 hours.
I then updated to V4.2, rebooted, power-cycled. No improvement.
Thanks for your support, -pl
Bildschirmfoto 2019-10-28 um 08.55.21.png (231.98 KiB) Viewed 4828 times
Bildschirmfoto 2019-10-28 um 08.14.40.png (274.85 KiB) Viewed 4828 times
meteolive57290
Post by meteolive57290 »
hello
exactly the same bug found today !
https://admin.meteobridge.com/cam/5c81a ... amplus.jpg
after the first observation of the absence of rain-total==0.0
see post
viewtopic.php?f=61&t=14462
SW Version: Meteobridge 4.2 (Oct 26 2019, build 13228), FW 1.4
i have exactly the same firmware installed on another device ... NO bug !
in connection with the solar time change ?
leliep
Post by leliep »
Don't know if this could be just accidential, but we just had the time change from summertime to wintertime.
svampen
Post by svampen »
PM with login sent to admin.
Aha! Nice idea about the time change.
My data seem to have disappeared from my reboot at about noon on the sunday. :?:
meteolive57290
guess the moment i encountered these dysfunctions on one of my MB in this case the one I rebooted yesterday at the end of the day so after the change of solar time ... the same bug was encountered by my reseller .... to be continued
Problem is caused by daylight saving change, where looping through the hours does not work when syncing the database. This causes an endless loop. So it is a hidden bug not related to the current version... which made it harder to find.
BTW: Just released Oct 28 update does fix it on Meteobridge PRO and NANO SD (both were affected).
Sorry for the inconvenience! It was a hidden bug waiting to show up when change from summer time to winter time happens.
meteolive57290
Re: No logging after update 26oct **solved**
hello yep resolved thnx for the support :wink:
like always
good week
best
svampen
Post by svampen »
Awesome work!! :D
Thank you so much for all effort!
leliep
Post by leliep »
Confirming it works with Meteobridge 4.2 (Oct 28 2019, build 2629), FW 1.3
Thanks again for your support!
