Upload data from the Nano SD + lost of connection
Lespius
Post by Lespius »
I currently use a Meteobridge Nano with Meteotemplate. For some reasons for several weeks now the connection with my router and network is lost, meaning I miss data.
--> Any idea why I had no problems for years and now every 7-10 days I need to reboot to fix the connection?
So I am considering buying the Nano SD (after having bought a standard Nano again viewtopic.php?f=56&t=14453 :( ), with its ability to store data. I was wondering if after a couple of hours or days of lost connection Meteotemplate will upload the missing data when connected again ?
Re: Upload data from the Nano SD
NANO SD will not behave differently. Beside the option of retries when upload has failed there is no special MT feature to fill gaps in MT based on data stored in the NANO SD.
I think you should find out why uploads fail on a regular basis with your setup. What kind of error messages do appear when uploads do no longer work?
Lespius
Post by Lespius »
I lose the connection with my WLAN too often.
Just right now it happened again.
I did several cold reboots, it starts flashing slowly and then it is stuck flashing quickly. Currently even when I choose the "meteobridge-B8D8..." network I am unable to reach it at the address http://192.168.169.1.
To answer your question I have no error message from meteobridge, just from MT saying that the station is offline...
Lespius
Re: Upload data from the Nano SD + lost of connection
Post by Lespius »
... and now it works... I am getting nuts
Could it come from a new release ??? I mean, could a new release cause temporary connectivity problems?
"Version SW: Meteobridge 4.2 (Nov 18 2019, build 2665), FW 1.4 "
Last releases did not make any changes in the networking section.
I have similar problems even a few times, today again ....
My Wlan connection lost for a minute, but after return connection, data not sent again to Home Weather Station and WU.
I noticed the failure just because the hws showed offline on displayed
The buffer on system tab kept on rising and nothing sent. I reboot the NanoSD and after that, the system works fine again.
Data not lost, after reboot comes
logger (19.11.2019 14:40:52): syncing.
database (19.11.2019 14:40:55): database sync done (25 tables, 75/2000 writes).
Lespius
Post by Lespius »
admin wrote: Tue Nov 19, 2019 1:37 am Last releases did not make any changes in the networking section.
Ok but any ideas why it disconnects from time to time ?
