Windy.com API key error in Weather Network tab **solved**
galfert
Post by galfert »
I'm seeing a Windy.com error in the Weather Network tab. But the Live data tab shows that it is uploading just fine and I see current data on Windy.com. It makes Weather Network tab slow to open up.
https://www.windy.com/station/pws-f075acbe
System Message
Error: Windy: invalid API key
MB Windy System Message.png (9.3 KiB) Viewed 4241 times
Also I see red X next to Windy API key and Station ID (which is 0).
MB Windy.png (16.77 KiB) Viewed 4235 times
I rebooted and problem still present.
System
Platform: TL-MR3020 (no USB hub)
RAM: 29364 kB total, 2012 kB free (93% used)
SW Version: Meteobridge 4.2 (Dec 11 2019, build 13290), FW 1.4
Uptime: 0 hours, 35 minutes Buffer: 1 items (0%)
Meteobridge RPI | GW1000
BigAlT
Re: Windy.com API key error in Weather Network tab
Post by BigAlT »
I’m seeing the same error. Must be a problem with Windy.
Taylor
Post by Taylor »
I see the same problem too. I also observed drops in data uploading to Windy last week. After updating the API key it works fine.
galfert
Post by galfert »
I too noticed some data dropouts last week for a few days. That seemed to be related to Windy's site. This week (since mid Thursday 19th) all data seems to be uploading just fine. Maybe Windy made a change to their API and their "SUCCESS" upload confirmation has changed. I have not looked into this yet, but I suspect that may be the problem.
I tried to copy/paste the API key from Windy and save it to the Meteobridge to see if that would fix the problem and it didn't make a difference. The key is right because if it weren't it would not be uploading. The problem is just with the Weather Network tab that shows an error that is not true and it delays the showing of the Weather Network tab when you select it.
pwilman
Post by pwilman »
Just logged into my nano SD and noticed the same issue with Windy.com
Paul
BigAlT
Post by BigAlT »
My error has now cleared.
Taylor
Post by Taylor »
You are right. No error now.
galfert
Re: Windy.com API key error in Weather Network tab **solved**
Post by galfert »
This issue for me is not solved. But I think the problem is with Windy. I'm not hearing back from Windy regarding this.
Is anyone with Meteobridge still having problems with Windy.com? It could be that just my Windy station ID account is messed up.
Taylor
Post by Taylor »
Yes, I see the Windy dropouts as well but on Meteobridge side everything looks OK.
galfert
Post by galfert »
I can't explain it but I basically deleted my Windy configuration API key from my Meteobridge and then copy/pasted it again and now everything is back to normal.
Since I just started uploading I won't know if the random outages of data upload will persist.
