Error Meteoplug Cloud en Meteoplug Cloud (Live) **solved**
BeBe
Post by BeBe »
Since yesterday Meteoplug Cloud and Meteoplug Cloud (Live) give an error message (attachment). I have rebooted and reset several times, but no result. I've had this before, but then it worked again after a reboot.
Upload to partners is ok.
Schermafbeelding 2020-03-06 om 11.02.36.jpg (72.4 KiB) Viewed 1662 times
logger (06.03.2020 09:31:21): databases connected. Update interval 3600 seconds.
logger (06.03.2020 09:31:21): data logger (version 5.1c, build 13419) started.
logger (06.03.2020 09:31:21): error (125) while doing bind (port 5551): Address already in use
logger (06.03.2020 09:31:21): killed process "14347/sh" listening to port 5551.
logger (06.03.2020 09:31:51): databases connected. Update interval 3600 seconds.
logger (06.03.2020 09:31:51): data logger (version 5.1c, build 13419) started.
logger (06.03.2020 09:31:51): error (125) while doing bind (port 5551): Address already in use
logger (06.03.2020 09:31:51): killed process "14348/meteosys" listening to port 5551.
logger (06.03.2020 09:32:21): databases connected. Update interval 3600 seconds.
logger (06.03.2020 09:32:21): data logger (version 5.1c, build 13419) started.
logger (06.03.2020 09:32:22): connect station 0 (Meteostick Vantage via USB serial).
logger (06.03.2020 09:32:22): connect station 9 (System Data via Plug-in).
logger (06.03.2020 09:32:22): transmitter 1 registered as ISS
logger (06.03.2020 09:32:22): transmitter 2 registered as Wind
logger (06.03.2020 09:32:22): transmitter 3 registered as Temperature
logger (06.03.2020 09:32:22): transmitter 4 registered as Temperature
logger (06.03.2020 09:32:22): Meteostick Version 2.5.2
logger (06.03.2020 09:32:22): debug off
logger (06.03.2020 09:32:22): verbose off
logger (06.03.2020 09:32:22): output raw (8 bytes)
logger (06.03.2020 09:32:22): output raw (10 bytes)
logger (06.03.2020 09:32:22): filter on
logger (06.03.2020 09:32:22): rx threshold set to -90db
logger (06.03.2020 09:32:22): listening to transmitter 1 2 3 4
logger (06.03.2020 09:32:22): bandwidth narrow
logger (06.03.2020 09:32:23): chip authentication ok: 14
logger (06.03.2020 09:32:23): frequency band 868MHz (EU)
logger (06.03.2020 09:32:25): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.03.2020 09:32:25): services paused.
logger (06.03.2020 09:33:24): sensors are now providing data.
logger (06.03.2020 09:33:24): services started.
logger (06.03.2020 10:02:31): databases connected. Update interval 3600 seconds.
logger (06.03.2020 10:02:31): data logger (version 5.1c, build 13419) started.
logger (06.03.2020 10:02:31): error (125) while doing bind (port 5551): Address already in use
logger (06.03.2020 10:02:31): killed process "17454/sh" listening to port 5551.
logger (06.03.2020 10:03:01): databases connected. Update interval 3600 seconds.
logger (06.03.2020 10:03:01): data logger (version 5.1c, build 13419) started.
logger (06.03.2020 10:03:01): error (125) while doing bind (port 5551): Address already in use
logger (06.03.2020 10:03:01): killed process "17455/meteosys" listening to port 5551.
logger (06.03.2020 10:03:31): databases connected. Update interval 3600 seconds.
logger (06.03.2020 10:03:31): data logger (version 5.1c, build 13419) started.
logger (06.03.2020 10:03:32): connect station 0 (Meteostick Vantage via USB serial).
logger (06.03.2020 10:03:32): connect station 9 (System Data via Plug-in).
logger (06.03.2020 10:03:32): transmitter 1 registered as ISS
logger (06.03.2020 10:03:32): transmitter 2 registered as Wind
logger (06.03.2020 10:03:32): transmitter 3 registered as Temperature
logger (06.03.2020 10:03:32): transmitter 4 registered as Temperature
logger (06.03.2020 10:03:32): Meteostick Version 2.5.2
logger (06.03.2020 10:03:32): debug off
logger (06.03.2020 10:03:32): verbose off
logger (06.03.2020 10:03:32): output raw (8 bytes)
logger (06.03.2020 10:03:32): output raw (10 bytes)
logger (06.03.2020 10:03:32): filter on
logger (06.03.2020 10:03:32): rx threshold set to -90db
logger (06.03.2020 10:03:32): listening to transmitter 1 2 3 4
logger (06.03.2020 10:03:32): bandwidth narrow
logger (06.03.2020 10:03:32): chip authentication ok: 14
logger (06.03.2020 10:03:33): frequency band 868MHz (EU)
logger (06.03.2020 10:03:35): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.03.2020 10:03:35): services paused.
logger (06.03.2020 10:04:39): sensors are now providing data.
logger (06.03.2020 10:04:39): services started.
logger (06.03.2020 10:23:37): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (06.03.2020 10:23:37): disconnect station 0 (Meteostick Vantage): exit
logger (06.03.2020 10:23:37): disconnect station 9 (System Data): exit
logger (06.03.2020 10:23:38): databases connected. Update interval 3600 seconds.
logger (06.03.2020 10:23:38): data logger (version 5.1c, build 13419) started.
logger (06.03.2020 10:23:39): connect station 0 (Meteostick Vantage via USB serial).
logger (06.03.2020 10:23:39): connect station 9 (System Data via Plug-in).
logger (06.03.2020 10:23:39): transmitter 1 registered as ISS
logger (06.03.2020 10:23:39): transmitter 2 registered as Wind
logger (06.03.2020 10:23:39): transmitter 3 registered as Temperature
logger (06.03.2020 10:23:39): transmitter 4 registered as Temperature
logger (06.03.2020 10:23:39): Meteostick Version 2.5.2
logger (06.03.2020 10:23:39): debug off
logger (06.03.2020 10:23:39): verbose off
logger (06.03.2020 10:23:39): output raw (8 bytes)
logger (06.03.2020 10:23:39): output raw (10 bytes)
logger (06.03.2020 10:23:39): filter on
logger (06.03.2020 10:23:39): rx threshold set to -90db
logger (06.03.2020 10:23:39): listening to transmitter 1 2 3 4
logger (06.03.2020 10:23:39): bandwidth narrow
logger (06.03.2020 10:23:40): chip authentication ok: 14
logger (06.03.2020 10:23:40): frequency band 868MHz (EU)
logger (06.03.2020 10:23:42): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.03.2020 10:23:42): services paused.
logger (06.03.2020 10:25:39): give up waiting for sensors after 120 secs.
logger (06.03.2020 10:25:39): services activated.
BeBe
Re: Error Meteoplug Cloud en Meteoplug Cloud (Live)
Post by BeBe »
When I reset the Live Data tab this afternoon, the malfunction had disappeared. Without a reboot.
What is this?
logger (06.03.2020 13:04:03): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (06.03.2020 13:04:03): disconnect station 0 (Meteostick Vantage): exit
logger (06.03.2020 13:04:03): disconnect station 9 (System Data): exit
logger (06.03.2020 13:04:05): databases connected. Update interval 3600 seconds.
logger (06.03.2020 13:04:05): data logger (version 5.1c, build 13419) started.
logger (06.03.2020 13:04:06): connect station 0 (Meteostick Vantage via USB serial).
logger (06.03.2020 13:04:06): connect station 9 (System Data via Plug-in).
logger (06.03.2020 13:04:06): transmitter 1 registered as ISS
logger (06.03.2020 13:04:06): transmitter 2 registered as Wind
logger (06.03.2020 13:04:06): transmitter 3 registered as Temperature
logger (06.03.2020 13:04:06): transmitter 4 registered as Temperature
logger (06.03.2020 13:04:06): Meteostick Version 2.5.2
logger (06.03.2020 13:04:06): debug off
logger (06.03.2020 13:04:06): verbose off
logger (06.03.2020 13:04:06): output raw (8 bytes)
logger (06.03.2020 13:04:06): output raw (10 bytes)
logger (06.03.2020 13:04:06): filter on
logger (06.03.2020 13:04:06): rx threshold set to -90db
logger (06.03.2020 13:04:06): listening to transmitter 1 2 3 4
logger (06.03.2020 13:04:06): bandwidth narrow
logger (06.03.2020 13:04:06): chip authentication ok: 14
logger (06.03.2020 13:04:06): frequency band 868MHz (EU)
logger (06.03.2020 13:04:07): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.03.2020 13:04:07): services paused.
logger (06.03.2020 13:05:07): sensors are now providing data.
logger (06.03.2020 13:05:07): services started.
Meteoplug had a server outage.
