MR3020 with v4.3 - console not responding - ideas to correct? **solved**
theorbo
Post by theorbo »
Hi - I'm hoping I can get some assistance. I've been a very satisfied user since early 2014 and have had no issues until recently after upgrading FW to 4.3 to get TLS for AmbientWeather access. Since upgrading the FW I've been getting a few minutes of data after a reboot but then seem to lose connection with console (no live data). I believe that I was on 3.7 or 3.8 before renewing license and upgrading FW.
My Weatherbridge device doesn't have any additional information like "V3" so I think it's V1? Other things I have tried include network/DNS resets, including removing batteries from the console, powering everything down including modem and router. Bringing up the modem, then router, then the console & Weatherbridge.
Any ideas of why this may be happening? What could I try or is there additional information I can provide to narrow down the issue?
Thanks, David
Platform: TL-MR3020 (plus USB hub)
RAM: 29364 kB total, 3060 kB free (89% used)
SW Version: Meteobridge 4.3 (Apr 7 2020, build 13444), FW 1.2
Davis Vantage Vue connected through USB hub
Log, immediately after reboot:
wnetd (14.04.2020 21:27:53): process started.
system (14.04.2020 21:27:54): start of logging process initiated.
wnetd (14.04.2020 21:27:54): send data thread started (pid:2543 tid:2545)
logger (14.04.2020 21:27:54): historical data loaded (24 records).
logger (14.04.2020 21:27:54): data logger (version 5.1d, build 13444) started.
logger (14.04.2020 21:27:55): connect station 0 (Vantage via USB serial).
logger (14.04.2020 21:27:55): wakeup sent.
logger (14.04.2020 21:27:58): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.04.2020 21:27:58): services paused.
logger (14.04.2020 21:27:59): no need to update console date/time.
logger (14.04.2020 21:27:59): setup script executed.
logger (14.04.2020 21:27:59): internal logger activated.
logger (14.04.2020 21:27:59): syncing.
logger (14.04.2020 21:28:09): gettime request sent.
logger (14.04.2020 21:28:19): message above repeats 1 time.
logger (14.04.2020 21:28:19): no Vantage time offset.
logger (14.04.2020 21:28:19): eeprom request sent.
logger (14.04.2020 21:28:19): rain collector size 0.01 inch per tick.
logger (14.04.2020 21:28:19): transmitter 1 active as station type #0 "ISS".
logger (14.04.2020 21:28:19): firmware version request sent.
logger (14.04.2020 21:28:19): firmware version 3.00 (supports LOOP2)
logger (14.04.2020 21:28:19): no reading of Vantage's internal logger.
logger (14.04.2020 21:28:23): sensors are now providing data.
logger (14.04.2020 21:28:23): services started.
logger (14.04.2020 21:43:19): child process received timeout signal (14).
logger (14.04.2020 21:43:19): disconnect station 0 (Vantage): exit
logger (14.04.2020 21:43:20): data logger stopped.
logger (14.04.2020 21:43:20): historical data loaded (24 records).
logger (14.04.2020 21:43:20): data logger (version 5.1d, build 13444) started.
logger (14.04.2020 21:43:21): connect station 0 (Vantage via USB serial).
logger (14.04.2020 21:43:21): wakeup sent.
logger (14.04.2020 21:43:24): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.04.2020 21:43:24): services paused.
logger (14.04.2020 21:43:34): execution of setup script failed (console is not responding).
logger (14.04.2020 21:43:34): internal logger activated.
logger (14.04.2020 21:43:34): syncing.
logger (14.04.2020 21:43:34): gettime request sent.
logger (14.04.2020 21:43:54): message above repeats 2 times.
logger (14.04.2020 21:44:04): disconnect station 0 (Vantage): timeout
logger (14.04.2020 21:44:34): connect station 0 (Vantage via USB serial).
logger (14.04.2020 21:44:34): execution of setup script failed (console is not responding).
<this sequence repeats>
Re: MR3020 with v4.3 - console not responding - ideas to correct?
Please reboot (power-cycle) the console. Sometimes its interface to the outside world hangs up.
theorbo
Post by theorbo »
Hello and thanks for the reply. I have tried that a few times, including once unplugging the MR3020 and leaving it disconnected for some time. Doing that again this morning I got similar results (see log below). Do you know of any other diagnostic things I could do to identify the source of the disconnection?
Thanks again - I appreciate all of your work on Meteobridge.
David
wnetd (20.04.2020 09:01:04): process started.
system (20.04.2020 09:01:04): start of logging process initiated.
wnetd (20.04.2020 09:01:04): send data thread started (pid:2465 tid:2467)
logger (20.04.2020 09:01:04): historical data loaded (24 records).
logger (20.04.2020 09:01:04): data logger (version 5.1d, build 13444) started.
logger (20.04.2020 09:01:05): connect station 0 (Vantage via USB serial).
logger (20.04.2020 09:01:05): wakeup sent.
logger (20.04.2020 09:01:08): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.04.2020 09:01:08): services paused.
logger (20.04.2020 09:01:09): no need to update console date/time.
logger (20.04.2020 09:01:09): setup script executed.
logger (20.04.2020 09:01:09): internal logger activated.
logger (20.04.2020 09:01:09): syncing.
logger (20.04.2020 09:01:19): gettime request sent.
logger (20.04.2020 09:01:19): no Vantage time offset.
logger (20.04.2020 09:01:19): eeprom request sent.
logger (20.04.2020 09:01:19): rain collector size 0.01 inch per tick.
logger (20.04.2020 09:01:19): transmitter 1 active as station type #0 "ISS".
logger (20.04.2020 09:01:19): firmware version request sent.
logger (20.04.2020 09:01:19): firmware version 3.00 (supports LOOP2)
logger (20.04.2020 09:01:19): no reading of Vantage's internal logger.
logger (20.04.2020 09:01:24): sensors are now providing data.
logger (20.04.2020 09:01:24): services started.
logger (20.04.2020 09:16:50): child process received timeout signal (14).
logger (20.04.2020 09:16:50): disconnect station 0 (Vantage): exit
logger (20.04.2020 09:16:51): data logger stopped.
logger (20.04.2020 09:16:51): historical data loaded (24 records).
logger (20.04.2020 09:16:51): data logger (version 5.1d, build 13444) started.
logger (20.04.2020 09:16:51): connect station 0 (Vantage via USB serial).
logger (20.04.2020 09:16:52): wakeup sent.
logger (20.04.2020 09:16:55): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.04.2020 09:16:55): services paused.
logger (20.04.2020 09:17:04): execution of setup script failed (console is not responding).
logger (20.04.2020 09:17:04): internal logger activated.
logger (20.04.2020 09:17:04): syncing.
logger (20.04.2020 09:17:04): gettime request sent.
logger (20.04.2020 09:17:24): message above repeats 2 times.
logger (20.04.2020 09:17:34): disconnect station 0 (Vantage): timeout
logger (20.04.2020 09:18:04): connect station 0 (Vantage via USB serial).
logger (20.04.2020 09:18:04): execution of setup script failed (console is not responding).
theorbo
Post by theorbo »
FYI - to close the loop on this, after trying the logger directly connected to a PC without issues, I tried replacing the USB hub and that has seemed to be the answer. Not sure why the previous USB hub went bad but it consistently would not work for any length of time with it, but since swapping-in a new USB hub I've had no issue.
Thanks again.
