MB PRO - export and graphic depiction of air quality sensors (air0pm, air1pm) fails ** solved **
Gyvate
Post by Gyvate »
I'm trying to export all my sensor values (by minute) at once via an export script, but somehow the air quality sensor data don't come.
it (MB-pro) shows the data in the live view and in the history tab for the respective sensor (at least the min/max/avg).
It doesn't change if I choose the hourly export option.
Then I tried to add the sensors to a .metachart graphics definition - it shows all sensors I define - but not the PM2.5 sensors (air0pm, air1pm).
What am I doing wrong ?
Please advise.
below script and result: (instead of the the , , , I would expect some values)
# modified Standard CSV template with data in metric units
$# date, time, temperature[C], humidity[%], dew point[C], sealevel pressure[hPa], avg wind speed[m/s], gust speed[m/s], winddir, rainfall[mm], Solar [W/m2], PM25(1) [ug/m3], PM25(2), extra-temp1 [°C], extra-hum [%], soil moisture (1) [%], SM2, SM3
[YYYY]-[MM]-[DD],[hh]:[mm],[th0temp-avg.1:],[th0hum-avg.0:],[th0dew-avg.1:],[thb0seapress-avg.1:],[wind0avgwind-avg.1:],[wind0wind-max.1:],[wind0dir-avg.0:],[rain0total-sum.1:], [sol0rad-avg.2:], [air0pm-avg.0:], [air1pm-avg.1:], [th1temp-avg.1:], [th1hum-avg.0:], [th20hum-avg.0:], [th21hum-avg.0:], [th22hum-avg.0:]
here is an excerpt of the created file
2020-05-14,11:48,14.1,52,4.3,1014.6,0.8,1.0,216,0.0, 926.00, , , 16.3, 47, 46, 52, 51
2020-05-14,11:49,14.3,52,4.5,1014.3,0.3,1.0,127,0.0, 929.50, , , 16.3, 46, 46, 52, 51
2020-05-14,11:50,14.4,52,4.7,1014.4,0.5,1.0,177,0.0, 916.67, , , 16.3, 46, 46, 51, 52
2020-05-14,11:51,14.4,52,4.7,1014.4,0.5,1.0,177,0.0, 916.67, , , 16.3, 46, 46, 51, 52
2020-05-14,11:52,14.4,52,4.7,1014.4,0.5,1.0,177,0.0, 916.67, , , 16.3, 46, 46, 51, 52
2020-05-14,11:53,14.4,52,4.7,1014.4,0.5,1.0,177,0.0, 916.67, , , 16.3, 46, 46, 51, 52
2020-05-14,11:54,14.7,51,4.5,1014.5,0.5,1.5,120,0.0, 912.50, , , 16.6, 46, 46, 52, 52
2020-05-14,11:55,14.9,50,4.6,1014.4,0.7,1.5,191,0.0, 901.00, , , 16.7, 46, 46, 52, 51
2020-05-14,11:56,14.9,51,4.9,1014.6,0.8,1.5,218,0.0, 902.40, , , 16.7, 46, 47, 52, 52
2020-05-14,11:57,14.7,51,4.7,1014.5,0.7,1.5,245,0.0, 900.00, , , 16.7, 46, 47, 51, 52
2020-05-14,11:58,14.6,49,4.0,1014.5,0.1,1.0,140,0.0, 897.00, , , 16.7, 45, 46, 51, 51
2020-05-14,11:59,14.7,49,4.2,1014.4,0.8,1.5,140,0.0, 895.33, , , 16.7, 45, 46, 52, 51
2020-05-14,12:00,14.9,49,4.3,1014.3,0.4,1.5,119,0.0, 889.25, , , 16.8, 45, 46, 52, 51
2020-05-14,12:01,15.0,48,4.1,1014.3,0.8,2.0,102,0.0, 900.00, , , 16.9, 45, 46, 52, 51
2020-05-14,12:02,15.4,48,4.5,1014.3,0.8,2.0,88,0.0, 905.00, , , 17.0, 44, 46, 52, 51
2020-05-14,12:03,15.5,49,4.7,1014.3,1.0,2.6,101,0.0, 861.00, , , 17.1, 44, 46, 52, 51
2020-05-14,12:04,15.5,48,4.5,1014.3,0.4,1.0,114,0.0, 798.25, , , 17.3, 45, 46, 52, 51
2020-05-14,12:05,15.5,49,4.7,1014.4,1.3,2.6,92,0.0, 579.50, , , 17.3, 45, 46, 52, 51
Live Data
Live Data
History Data
History Data
With a software update today the issue was solved and the [air0pm-avg.1:] and [air1pm-avg.1:] variables are now filled with proper values.
Meteobridge 4.3 (May 28 2020, build 13497), FW 1.4
Meteobridge 4.3 (May 28 2020, build 13497).JPG (53.98 KiB) Viewed 4015 times
2020-05-28,21:00,19.5,33,2.8,1024.9,0.2,0.5,99,0.0, 10.00, 5.0, 5.0, 21.7, 29, 39, 47,
2020-05-28,21:01,19.5,33,2.8,1024.8,0.4,1.0,98,0.0, 9.33, 5.0, 5.0, 21.7, 30, 39, 46,
2020-05-28,21:02,19.3,33,2.6,1024.8,0.2,1.0,96,0.0, 8.50, 5.0, 5.0, 21.7, 30, 39, 47, 37
2020-05-28,21:03,19.3,33,2.6,1024.9,0.2,0.5,102,0.0, 8.00, 4.5, 5.0, 21.7, 30, 39, 46, 37
2020-05-28,21:04,19.2,34,2.8,1024.9,0.2,0.5,99,0.0, 8.00, 4.0, 5.0, 21.7, 30, 39, 47, 37
Graph of minute based PM2.5 sensor data
