Meteobridge stops logging data randomly.
rmccullough
Post by rmccullough »
My station started randomly going offline every couple days. The last time it happened I rebooted my Meteobridge device(TL-MR3020) and it was working fine once it started back up. This time I just clicked Save button in the Weather Station tab, which restarted the datalogger. Any ideas on what I can do to troubleshoot? This setup has been running nearly flawlessly since 2014.
Here are the logs from the most recent event.
logger (19.06.2020 18:20:41): historical data loaded (20 records).
logger (19.06.2020 18:20:41): data logger (version 5.1d, build 13568) started.
logger (19.06.2020 18:20:42): connect station 0 (Vantage via USB serial).
logger (19.06.2020 18:20:42): wakeup sent.
logger (19.06.2020 18:20:45): sensors are now providing data.
logger (19.06.2020 18:20:45): services started.
logger (19.06.2020 18:20:46): no need to update console date/time.
logger (19.06.2020 18:20:46): setup script executed.
logger (19.06.2020 18:20:46): internal logger activated.
logger (19.06.2020 18:20:46): syncing.
logger (19.06.2020 18:20:56): gettime request sent.
logger (19.06.2020 18:20:56): no Vantage time offset.
logger (19.06.2020 18:20:56): eeprom request sent.
logger (19.06.2020 18:20:56): rain collector size 0.01 inch per tick.
logger (19.06.2020 18:20:56): transmitter 1 active as station type #0 "ISS".
logger (19.06.2020 18:20:56): firmware version request sent.
logger (19.06.2020 18:20:56): firmware version 3.15 (supports LOOP2)
logger (19.06.2020 18:20:56): no reading of Vantage's internal logger.
logger (19.06.2020 18:40:49): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getlin...
logger (19.06.2020 18:40:49): disconnect station 0 (Vantage): exit
system (19.06.2020 19:03:33): stop of logging process initiated.
logger (19.06.2020 19:03:33): parent process received termination signal (15).
system (19.06.2020 19:03:35): start of logging process initiated.
logger (19.06.2020 19:03:35): historical data loaded (20 records).
logger (19.06.2020 19:03:35): data logger (version 5.1d, build 13568) started.
logger (19.06.2020 19:03:36): connect station 0 (Vantage via USB serial).
logger (19.06.2020 19:03:36): wakeup sent.
logger (19.06.2020 19:03:39): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (19.06.2020 19:03:39): services paused.
logger (19.06.2020 19:03:40): no need to update console date/time.
logger (19.06.2020 19:03:40): setup script executed.
logger (19.06.2020 19:03:40): internal logger activated.
logger (19.06.2020 19:03:40): syncing.
meteolive57290
Re: Meteobridge stops logging data randomly.
Post by meteolive57290 »
hello same malfunction encountered this morning on my two MB-Pro
stop disconnect at 02:52 and 05:27 ...also send on WL_Cloud
uoplad WL_Cloud
uoplad WL_Cloud
for log extract ! left after the same operation (clicked SAVE button) ...
kind regards
logger (20.06.2020 02:52:36): transmitter 8 active as station type #4 "Wind".
logger (20.06.2020 02:52:36): firmware version request sent.
logger (20.06.2020 02:52:37): firmware version 3.12 (supports LOOP2)
logger (20.06.2020 02:52:37): no reading of Vantage's internal logger.
logger (20.06.2020 03:14:13): child process received timeout signal (14).
logger (20.06.2020 03:14:13): disconnect station 0 (Vantage): exit
logger (20.06.2020 03:14:13): disconnect station 9 (System Data): exit
system (20.06.2020 07:27:44): stop of logging process initiated.
logger (20.06.2020 05:27:15): child process received timeout signal (14).
logger (20.06.2020 05:27:15): disconnect station 0 (Vantage): exit
logger (20.06.2020 05:27:15): disconnect station 9 (System Data): exit
system (20.06.2020 07:25:40): stop of logging process initiated.
logger (20.06.2020 07:25:40): parent process received termination signal (15).
logger (20.06.2020 07:25:40): child process received termination signal (15).
system (20.06.2020 07:25:41): start of logging process initiated.
system (20.06.2020 05:25:42): start of logging process initiated.
meteolive57290
edit_
second stop noted in the process for one of my two MB :oops: :oops:
functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (20.06.2020 09:37:18): disconnect station 0 (Vantage): exit
system (20.06.2020 09:44:55): stop of logging process initiated.
system (20.06.2020 09:45:02): start of logging process initiated.
