lost data nanov2 **solved**
Ger
Post by Ger »
My console lost his WiFi connection yesterday evening. This morning I was able to restore the connection. But all the data are lost. How is this possible? The Nano SD have 2 Gb memory on board. What is that used for if it doesn't save the data?
Re: lost data nanov2
It stores the data for sure. Your description does not provide any detail to support.
Ger
Post by Ger »
Thanks for reply, what do you want for information? I see nothing in meteobridge during the timeout of Wifi
screen dumps of the tabs that prove that data is not stored would be a first step.
Is there nothing on "historical data" tab?
What does messages section on "system" tab tell you.
Ger
Post by Ger »
I'm now back for a few days on the island. There was again the same problem ( staion lost contact with WiFi account. I have made a screenshot of the result Image. You can see there is no data uploaded before 09:00, the moment that I repaired the connection. One more question, is it normal that the maximum period for a chart is only 2 days?
Data in per minute resolution is just stored in a RAM with a capacity of 48 or 72 hours. Per hour data is stored infinitely on SD card.
Ger
Post by Ger »
Could my SD card not work? Or do I have to set the software differently so that it retrieves the data from the SD card? If so how?
Ger
Post by Ger »
Finally I got today a new nanoSD from the supplier, problems solved
