template.cgi missing? **solved**
fortunatech
Post by fortunatech »
The MB Wiki instructs to use the "template.cgi" script in a URL call to return data directly from the software. It gives an example of http://ip-of-meteobridge/cgi-bin/template.cgi?template=[DD...
This template is useful to obtain yesterday's min/max data from soil sensors in the garden directly from a browser window.
Using version 4.4 version after 10/12, MB's response to a template query is "no such file or directory". Has the path changed?
ve7gel
Re: template.cgi missing?
Post by ve7gel »
I have this issue too when querying Meteobridge. A query from my irrigation system or home automation controller both fail with "No such file or directory" as well.
P.S. I logged in via SSH and checked for the presence of the template....it does indeed seem to be missing.
kurite
Post by kurite »
I too am missing template.cgi in the latest firmware but the other cgi interfaces are available. A bit frustrating since I just set up a Siri Shortcut to read me the current weather from template.cgi (super easy to use!)
TL-MR3020 (no USB hub)
Meteobridge 4.4 (Oct 14 2020, build 13969)
It is there with the current version. Which platform are you on?
ve7gel
Post by ve7gel »
I have a TP-MR3020v1. The problem was there with the October 14 update, and I haven't tried the most recent update. I was waiting for confirmation that it was fixed, so will try it a bit later today. Thanks for the info
kurite
Post by kurite »
I just got 5.0, same issue of missing template.cgi:
Meteobridge 5.0 (Oct 17 2020, build 13977), FW 1.4
You are right, on MR3020v1 the file has been stripped by error from the latest releases. It is added again. Final version 4.4 as well as new 5.0 do have it again. Please do a reboot.
ve7gel
Re: template.cgi missing? **solved**
Post by ve7gel »
Thanks for the update. Rebooted with V5 and it is now working properly.
kurite
Post by kurite »
Yes, it is there now on Meteobridge 5.0 (Oct 17 2020, build 13979), FW 1.4
Awesome support. Thank you very much.
