Scheduled mail sending. **solved**
marioferrari22
Post by marioferrari22 »
with the following configuration (see attachment):
smtp. port 587
STARTTLS authentication
By running the "Test Email", the test email is invited.
then:
by scheduling an e-mail sending for the period of 2 minutes, the e-mail is invited.
If, on the other hand, the scheduling is inserted every 6 hours it does not work.
Why
(I also tried every 2 hours, but it doesn't work the same)
Schermata 2020-11-24 alle 21.10.03.png (27.24 KiB) Viewed 1255 times
Re: Scheduled mail sending
When you see restarts of the logger in "system - logging" tab that is the reason. Timer resets on each restart.
marioferrari22
Ok solved.
Thanks for your help.
Bye
