Meteobridge will not load application stack. WR902ACv3 **solved**
telvana
Post by telvana »
Greetings,
I cannot for the life of me get my meteobridge back online. It refuses to load the application stack, even though it has full access to the internet.
Meteobridge Hardware: TP-Link TL-WR902ACv3
Here's what it's stuck at.
IMAGE LOAD PROTOCOL:
--2021-01-02 05:59:05-- http://download.meteobridge.com/cgi-bin ... KcCoAbHhFi
Resolving download.meteobridge.com... 88.99.105.253, 2a01:4f8:10a:f98::4711
Connecting to download.meteobridge.com|88.99.105.253|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: '/tmp/image.tgz'
0K 8.73M=0s
2021-01-02 05:59:05 (8.73 MB/s) - '/tmp/image.tgz' saved [661]
I have tried changing DNS servers, I've tried using the Meteobridge wirelessly, etc. Nothing works. I can download the file to my PC manually, which works just fine so something somewhere isn't quite right with the Meteobridge itself.
UPDATE:
I reflashed V1.3, still no change. I did however dig a bit deeper into the logs that OpenWRT spews and I found this. Not sure what it's significance is though.
Tue Jan 2 16:23:48 2018 daemon.notice procd: /etc/rc.d/S95done: check for patched factory partition
Tue Jan 2 16:23:48 2018 daemon.notice procd: /etc/rc.d/S95done: ABORT: factory partition already patched
Tue Jan 2 16:23:49 2018 daemon.notice procd: /etc/rc.d/S95done: rescue download to be started
Tue Jan 2 16:23:49 2018 daemon.notice procd: /etc/rc.d/S95done: /tmp/rescue: line 1: syntax error: unexpected newline
Tue Jan 2 16:23:49 2018 daemon.notice procd: /etc/rc.d/S95done: rescue download ended
Tue Jan 2 16:24:36 2018 kern.notice kernel: [ 92.648092] random: crng init done
marioferrari22
Re: Meteobridge will not load application stack. WR902ACv3
Post by marioferrari22 »
Even yesterday I could not start the Meteobridge TL-MR3020 V3,
I had to revert to the Meteobridge 5.0 release (Jan 1 2021, build 3684), FW 1.3,
Now with this version it works.
Greetings
There have been no changes between 5.0 and fresh 5.1 that are expected to have an impact on the startup. I just powered-up my WR902ACv3 and it comes up fine. See yourself...
Bildschirmfoto 2021-01-03 um 13.34.10.png (131.6 KiB) Viewed 1423 times
marioferrari22
Now with build 3688, version 5.1 works,
ottomo,
yesterday it went on a loop.
Sistema
Piattaforma: TL-MR3020V3 (Nessun hub USB)
RAM: 60592 kB totale, 18520 kB gratuito (69% usato)
Versione SW: Meteobridge 5.1 (Jan 2 2021, build 3688), FW 1.3
Uptime: 0 Ore, 5 Minuti Buffer: 3 elementi (0%)
