change sd card raspberry **solved**
norvegese
Post by norvegese »
hi to all. if I change sd card to my raspberry can I copy all the old data? Does the license change or does the old one remain?
BigAlT
Re: change sd card raspberry
Post by BigAlT »
The procedure for backing up and restoring the Nano SD database should also work for the Raspberry Pi
viewtopic.php?f=57&t=15413
As to your question regarding the license, you’ll have to wait for Boris to respond. There is no mention of a license transfer being necessary in the Nano SD Card transfer instructions but I do remember it being necessary when changing SD cards in the Meteohub RPi, so only Boris can answer your question.
galfert
Post by galfert »
The Meteobridge license is tied to the device's MAC address. You can change SD card or format it and it will not affect the license.
Meteobridge RPI | GW1000
George is right, changing SD card does not impact license. This is different from Meteohub, where it did.
Andyk1
Post by Andyk1 »
As a side note... If you are using a template to view your station... Remember to change your camera settings to reflect the new camera uploads.
FOR example, I am using meteotemplate. I spent days trying to figure out why my camera FTP uploads were not reflected in the new meteobridge setup moved to a new Rpi 4 from a Rpi3-B+. Meteobridge uses your mac address to verify things as Licensing and so on. In my case, it also changes my camera FTP upload address to: https://admin.meteobridge.com/cam/e5996 ... amplus.jpg. My older Rpi 3b+ used a different upload viewing address. This of course is for Meteotemplate but I am assuming this will be the same for everyone changing devices.
Making an exact copy of your "meteobridge-2021-01.21.conf" <<< example, and using the restore feature will not correct the camera update URL and must be done manually. Don't do like I did and pull your hair out looking for the problem.
