Meteohub Locked Up
cbhiii
Meteohub Locked Up
Post by cbhiii »
Just before bed tonight I found out that my Meteohub was locked up (on, but dead). It appears to have been locked up for about 12 hours today.
No flashing lights at all. No LAN access. Just solid lights that do nothing.
I rebooted the unit and found that no data was collected today while it was locked up.
The Meteohub log had the following errors in it:
wmr928eval (21.07.2008 10:21:17): illegal data record in line 376779 while reading from file /data/weather/200807/raw: 200807211133220sl0 5420080721113322 wynd0 265 13013 019620080721113322 rayn0 0 0 496120080721113326 wi~d0 266 13013 0196
wmr928eval (21.07.2008 10:21:17): illegal data record in line 376780 while reading from file /data/weather/200807/raw: 200807211133300wind0 267 13013 0196
wmr928eval (21.07.2008 10:21:17): illegal data record in line 376797 while reading from file /data/weather/200807/raw: 200807211134360wy~d0 274 18013 019720080721113442 wy~d0 272 18013 019720080721113444 th0 196 9600189200807211134440wynt00268 18 1300196
wmr928eval (21.07.2008 10:21:17): illegal data record in line 376798 while reading from file /data/weather/200807/raw: 200807211134480wynd0 273 2201300196
wmr928eval (21.07.2008 10:21:17): illegal data record in line 376799 while reading from file /data/weather/200807/raw: 200807211134500wy~d0 274 2201300196
wmr928eval (21.07.2008 10:21:17): illegal data record in line 376803 while reading from file /data/weather/200807/raw: 200807211134580wynt0 274013 1300196
wmr928eval (21.07.2008 10:21:17): illegal data record in line 376804 while reading from file /data/weather/200807/raw: 200807211135000wynt0 280013 1300196
wmr928eval (21.07.2008 10:21:17): illegal data record in line 376805 while reading from file /data/weather/200807/raw: 200807211135060wynt00272 13 13 0196
wmr928eval (21.07.2008 10:21:17): illegal data record in line 376806 while reading from file /data/weather/200807/raw: 200807211135120wint00271 9 13 0196
wmr928eval (21.07.2008 10:21:17): illegal data record in line 376825 while reading from file /data/weather/200807/raw: 200807211136340sl0 5320080721113634 wi~d0 278 9 1300196
After seeing similar errors again tonight after rebooting, I ran the 'data cleanup' procedure. And now I wait to see if this is fixed.
I just replaced the USB drive with a brand new formatted unit and did a new install of the Meteoub software so I doubt there is a problem with the USB stick.
Any other ideas? Thanks.
Re:Meteohub Locked Up
I remember you had trouble from the start in with your unit. If you can rule out the USB stick, as having replaced this with a fresh one, I fear your NSLU2 might not working correctly, at least not all of the time.
I know of at least one other user, who had constantly trouble with his setup until finally replacing the NSLU2.
The situation you have at the moment is very frustrating, as this all looks like errors that are going to make your file system inconsistent... and this will bring up an endless list of new errors. Do you have a chance to replace your NSLU2?
A drawback of the NSLU2 being very cheap is that some units don't work very well on the long run.
cbhiii
Post by cbhiii »
Since I cleaned the data up, there have been no issues.
I will keep an eye on it.
I don't want to get another NSLU2 if you may change to another piece of equipment in the future.
