Weaterlink
Roffemas
Weaterlink
Post by Roffemas »
I have a meteobridge PRO, vantage vue and an USB-logger.
Running catalina on my Mac does it impossible to run WeatherLink software.
I have read read about sending via meteobridge to WeatherLink, but is that possible without WeatherLink software for the USB-logger?
And there isn`t any WeatherLink alternative in the dropdown meny for networks either...
Re: Weaterlink
Using the forum search can help:
viewtopic.php?t=15172
Roffemas
Re: Weaterlink
Post by Roffemas »
But my concern is, should I connect the loggers usb cable directly to the Meteobridge PRO?
Re: Weaterlink
Roffemas wrote: Sun Mar 28, 2021 11:54 am But my concern is, should I connect the loggers usb cable directly to the Meteobridge PRO?
That is basically the only option, but note any mention regarding the possible requirement of a USB hub, the MBPro then becomes the interface (connected via your router) between the sensor data and being able to upload to WeatherLink.com
Roffemas
Re: Weaterlink
Post by Roffemas »
Ok, so no it`s feeding weatherlink :D
But at first it didn`t work untill i unchecked the box ”sync stations time/date with the internet”
