Installed it, a question (or two) ** solved **
J.S.
Post by J.S. »
Hi, I installed it. A second small USB stick came in handy btw.
I have accessed my meteohub via another IP address with IPscan and got connected. It says the demo will last me another 68 days (ie 1 oktober I guess). Is this correct?
RFXCOM was found. I have browsed threw the software and sensors. Suppose I have three 810 temperature sensors, will they be called differently. It seems as it you can only call one 810...for instance.
Thanks again. I am very happy thusfar. secondhand NSLU2 works great!
Re:Installed it, a question (or two)
Post by skyewright »
J.S. wrote:RFXCOM was found. I have browsed threw the software and sensors. Suppose I have three 810 temperature sensors, will they be called differently. It seems as it you can only call one 810...for instance.
On the Meteohub "Sensors" page you allocate each sensor to a different ID from a drop down list, e.g. th0, th1, etc., and you can also give each sensor a 'name'.
For example I have two THWR288 sensors, which I choose to allocate to IDs t7 and t8, and to name as "Solar-B" and "Soil-A" (arbitray names that have meaning to me :) ).
Does that make sense now?
