Distinguish between multiple stations. **solved**
pehon
Post by pehon »
Hello!
I would like to get my weather station date on behalf of a XML request:
# curl -s http://xx:xx@mb.myurl/cgi-bin/livedataxml.cgi |grep "TH" | sort
  <TH date="20220307192915" id="th0" temp="-0.5" hum="69" dew="-5.5" lowbat="0" />
  <TH date="20220307192924" id="th2" temp="0.2" hum="68" dew="-5.0" lowbat="0" />
  <TH date="20220307192926" id="th0" temp="0.8" hum="69" dew="-4.2" lowbat="0" />
  <THB date="20220307192915" id="thb0" temp="-0.5" hum="69" dew="-5.5" press="941.7" seapress="1020.3" fc="-1" lowbat="0" />
  <THB date="20220307192918" id="thb0" temp="27.2" hum="30" dew="8.1" press="942.2" seapress="1020.9" fc="-1" lowbat="0" />
Hmm, there are two times "th" and "thb0", but that are actually different stations. How do i distinguish between them?
I have two Davis IIS connected to a Meteostick and a tempest weather station.
Line1: Tempest (without pressure?)
Line2: Davis IIS
Line3: Davis IIS
Line4: Tempest Weatherflow
Line5: Meteostick USB (because of temp="27.2")
For my it looks like the automatic sensor naming is doing something bad. Why not just display them as added (or like it was working perfectly with Meteohub)?
Peter
Some logs about stations
Raw Sensor Output - Live Data
Station1 (Tempest Weatherflow)
Meteostick with two IIS
Re: Distinguish between multiple stations
Thanks for spotting this. The live data thing was designed before multiple station support was added.
I will think a bit how to solve this. Just adding a new name-value pair like 'station="1"' might be a way out. Would this help?
pehon
Post by pehon »
In my case that would help. But think about other users using livedataxml.cgi, they could get errors while parsing.
I would add an additional cgi without any magic renaming, e.g. livedataxml_raw.cgi or livedataxml_with_station.cgi. But take care, that no sensor will ever be renamed, even if you remove or add new stations.
pehon
Post by pehon »
Will there will be a solution for this issue in one of the next meteobridge releases?
And, is MQTT and InfluxDB in the roadmap?
Latest release does have this:
adds an option to "livedataxml.cgi" to print out "station=X" as an additional XML parameter of each sensor. This indicates which station a sensor belongs to and can be usefull when driving multiple weather stations with Meteobridge. This option is enabled by adding the URL parameter "includestation" when calling "livedataxml.cgi". Example below shows XML output when called with "includestation" option.
  <TH date="20220313214052" id="th0" station="0" temp="7.5" hum="38" dew="-5.9" lowbat="0" />
  <T date="20220313214010" id="t8" station="0" temp="3.9" lowbat="0" />
  <SOIL date="20220313214010" id="th10" station="0" temp="3.9" hum="255" lowbat="0" />
  <SOIL date="20220313214010" id="th11" station="0" temp="0.0" hum="200" lowbat="0" />
  <LEAF date="20220313214010" id="th15" station="0" temp="3.9" hum="255" lowbat="0" />
  <LEAF date="20220313214010" id="th16" station="0" temp="0.0" hum="0" lowbat="0" />
  <UV date="20220313214010" id="uv0" station="0" index="0.0" lowbat="0" />
  <SOL date="20220313214010" id="sol0" station="0" rad="0" lowbat="0" />
  <WIND date="20220313214102" id="wind0" station="0" dir="347" gust="0.0" wind="0.0" chill="7.5" lowbat="0" />
  <RAIN date="20220313214010" id="rain0" station="0" rate="0.0" total="0.0" delta="0.0" lowbat="0" />
  <THB date="20220313214010" id="thb0" station="0" temp="30.8" hum="20" dew="5.2" press="1017.8" seapress="1021.1" fc="2" lowbat="1" />
  <DATA date="20220313214100" id="data10" station="9" val="19.00" lowbat="0" />
  <DATA date="20220313214101" id="data11" station="9" val="11.39" lowbat="0" />
  <DATA date="20220313214101" id="data12" station="9" val="2.00" lowbat="0" />
  <DATA date="20220313214101" id="data13" station="9" val="56.00" lowbat="0" />
  <DATA date="20220313214101" id="data15" station="9" val="64.00" lowbat="0" />
  <DATA date="20220313214101" id="data16" station="9" val="2.00" lowbat="0" />
pehon wrote: Tue Mar 15, 2022 9:50 pm And, is MQTT and InfluxDB in the roadmap?
nope.
pehon
Post by pehon »
admin wrote: Thu Mar 17, 2022 1:57 pm Latest release does have this:
gorgeous, works like a charm
# curl -s http://x:y@myurl/cgi-bin/livedataxml.cgi?includestation |grep TH
  <TH date="20220317195920" id="th0" station="0" temp="9.2" hum="81" dew="6.1" lowbat="0" />
  <TH date="20220317195907" id="th2" station="0" temp="8.4" hum="82" dew="5.5" lowbat="0" />
  <THB date="20220317195906" id="thb0" station="0" temp="27.8" hum="30" dew="8.6" press="951.1" seapress="1027.8" fc="-1" lowbat="0" />
  <TH date="20220317195922" id="th0" station="1" temp="8.0" hum="86" dew="5.8" lowbat="0" />
  <THB date="20220317195922" id="thb0" station="1" temp="8.0" hum="86" dew="5.8" press="950.4" seapress="1027.0" fc="-1" lowbat="0" />
