Sftp event issue. **solved**
wx-dave
Post by wx-dave »
Hi all,
I have a Meteobridge Pro running version 5.3. Within the last week I noticed that my data on my site was stale for the sftp upload. I am able to do the test SFTP service successfully every time with no issue. The event triggers once without issue after every reboot. However I can see on my firewall logs that the initial upload goes through then the event doesn’t try again after that. I tried deleting and recreating the event and that did not work. I also tried going back in firmware as far as version 5.1. I also verified that my ISS values are being received regularly. Not sure what else to look at next, any suggestions would be greatly appreciated.
——-Dave
Re: Sftp event issue
What does the event log on tab "live data - upload status" tell? Can you see the events being triggered as expected?
If not, please check in "System - Log Files" tab that the logger process is running uninterrupted and is not restarting again and again. If it is in a restart loop, please solve the issue with your station definition.
wx-dave
Post by wx-dave »
Thank you for the quick response!
I can see that my upload to Weather Underground looks good and current, my HTTP errors out on occasion, but does seem to be updating the site, also my triggered display upload looks good. The SFTP one shows a green check mark, but only has the timestamp from when I first rebooted the Meteobridge Pro.
When I first looked into this it did appear that I had a reception issue with the station, but I definitely fixed that and the triggered display is now set for the RF analysis and shows that it's receiving transmissions from the ISS at 62db regularly. I did also try the approach with setting my console to retransimit as the instructions note and that worked for a bit and then stopped (need to investigate that further). However when I put it back to Station ID #1 which is what the ISS transmits on and that's working again.
Below are the logs. They show about the time that I performed the reboot, but I don't see any updates since then (see below). Thank you for your input on this, greatly appreciated!
oled (03.04.2022 12:19:18): process started.
setup (03.04.2022 08:21:57): use UTC stamp 2022-04-03 12:21:57 (1 tries)
database (03.04.2022 08:22:07): process started.
database (03.04.2022 08:22:07): Content of RAM database restored.
wnetd (03.04.2022 08:22:11): process started.
system (03.04.2022 08:22:11): start of logging process initiated.
wnetd (03.04.2022 08:22:11): send data thread started (pid:2412 tid:2415)
logger (03.04.2022 08:22:11): databases connected. Update interval 3600 seconds.
logger (03.04.2022 08:22:11): data logger (version 5.2, build 14700) started.
logger (03.04.2022 08:22:13): connect station 0 (Meteostick Vantage via USB serial).
logger (03.04.2022 08:22:13): connect station 9 (System Data via Plug-in).
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), Meteostick Version 2.5.2
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), debug off
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), verbose off
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), filter on
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), rx threshold set to -80db
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), listening to transmitter 1
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), bandwidth narrow
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), chip authentication ok: 14
logger (03.04.2022 08:22:15): station 0 (Meteostick Vantage), frequency band 915MHz (US)
logger (03.04.2022 08:22:16): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (03.04.2022 08:22:16): services paused.
database (03.04.2022 08:22:29): database sync done (61 tables, 23/1883 writes).
logger (03.04.2022 08:24:13): give up waiting for sensors after 120 secs.
logger (03.04.2022 08:24:13): services activated.
Log looks ok. When you give me a remote login, I can have a closer look why the SFTP upload events are not triggered as expected.
Regarding remote login, please read here: viewtopic.php?f=57&t=9885
I need the specific URL and password. Please send to info(at)meteobridge.com, if you like.
wx-dave
Post by wx-dave »
Hi, I sent the info a little while ago. Thanks again for your assistance.
Thanks for providing remote login. I have inspected with these findings:
1) SFTP works ok
2) HTTP upload to your server are too slow for a 5 sec interval, I updated to 10 sec interval
From my point of view things are now fine. Please avoid to fire multiple events on a 5 sec base.
