MB suddenly stopped working
WETRHE
Post by WETRHE »
unfortunately my MB suddenly stopped working, database seems to be not available anymore. Pls. see screenshots.
What has happened? Any chance to get the lost data back?
WETRHE
Re: MB suddenly stopped working
Post by WETRHE »
Nobody an idea? It seems that the internal memory or disk has crashed:
Only a small extract of the log which is showing the attempts of MB all the time:
database (18.04.2022 19:00:22): cannot commit (after 0 tries in 1ms): cannot commit - no transaction is active (1)
database (18.04.2022 19:00:22): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active (1)
database (18.04.2022 19:00:22): cannot prepare insert into 'sol0rad_min' RAM (after 0 tries in 1ms): no such table: sol0rad_min (1)
database (18.04.2022 19:00:22): rollback on insert forced (1) (min RAM): sol0rad
database (18.04.2022 19:00:22): cannot create table (after 0 tries in 1ms): database or disk is full (13)
database (18.04.2022 19:00:23): cannot create table (after 0 tries in 1ms): database or disk is full (13)
database (18.04.2022 19:00:23): cannot commit (after 0 tries in 1ms): cannot commit - no transaction is active (1)
database (18.04.2022 19:00:23): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active (1)
database (18.04.2022 19:00:23): cannot prepare insert into 'sol0rad_min' RAM (after 0 tries in 1ms): no such table: sol0rad_min (1)
database (18.04.2022 19:00:23): rollback on insert forced (1) (min RAM): sol0rad
What are the details of the storage device on the Information>System page?
WETRHE
Post by WETRHE »
All my own templates are also missing and if I try to copy these to MB it says:
Ciemon
Post by Ciemon »
It says no space left on device. Is the storage full, or failed?
Regards,
@Ciemon
@VillageWeather
villageweather.net
WETRHE
Post by WETRHE »
It's shouldn't be full rather failed. But what would be a solution? Is it hardware storage which failed? Any chance to get the data back?
At this time MB is not running correctly anyway, so it's useless.
That would be a rather large standard consumer grade USB and my guess has seen a lot of read/write and my guess has probably failed?
WETRHE
Post by WETRHE »
Yes, I gues that it is defekteive but what would be a solution to get it working again?
Mattk wrote: Tue Apr 19, 2022 10:50 am That would be a rather large standard consumer grade USB and my guess has seen a lot of read/write and my guess has probably failed?
Sorry I need to correct that as I mistook the RAM value for the Storage details which normally sits between the RAM & SW version lines. The unit is not recognizing the USB storage (at all) which does tend to indicate some sort of storage issue.
You could pull the unit apart and re-seat the USB but I suspect the USB is failed?
Do you know what make/model the USB in this unit is as these details are not showing?
WETRHE wrote: Tue Apr 19, 2022 11:02 am Yes, I gues that it is defekteive but what would be a solution to get it working again?
If the internal USB is a consumer grade unit then life expectancy can be short. If a failed USB then would require a new USB. USB is not all that difficult to change out
WETRHE
Post by WETRHE »
I swaped the internal USB storage and it seems to work fine again ... unfortunately all data and own templates are lost :(
WETRHE wrote: Tue Apr 19, 2022 1:17 pm I swaped the internal USB storage and it seems to work fine again ... unfortunately all data and own templates are lost :(
What kind of stick was in the MB PRO? Was it the 1GB ATP SLC?
WETRHE
Post by WETRHE »
It is labled with: "ATP NANDDURA 1GB"
Gyvate
Post by Gyvate »
data written to \\METEOBRIDGE\data and its subdirectories uses space on the internal storage (on a MB Pro usually max 1 GB).
the simplest solution is to save/copy created exports onto the PC (when using Windows) and then delete data from the .\data\export directory
regularly to free space. The database directory and the export subdirectory are usually the directories with the biggest growth.
As the growth of the database cannot be reduced, the content of the ...\data\export subdirectory can.
Another option is to extend the internal memory by replacing the 1 GB internal SLC USB storage with bigger SLC storage (e.g. by an 8 GB (or bigger) SLC microSD with a USB adapter (I've extended mine with an 8 GB microSD)). Real SLC USB sticks of bigger size cost a fortune, hence the SLC microSD solution !
Works perfectly !! :)
@WERTHE: the screen shot in your first posting ist missing the storage line. This indicates that USB storage has not been recognized during boot. Do you still have that symptom?
