Meteobridge Pro Display Settings
Udo
Post by Udo »
Hi, I‘m new here and sorry if my question below has been answered already.
How can I set the display to show Wind speed and Wind guest in Kn.
After reset to factory settings this setting got lost 😩
The display do only show two vertical bars moving from the edge to the middle.
Udo
Re: Meteobridge Pro Display Settings
What you see is the screen saver. You need to define a display event on "Events" tab.
Udo
Post by Udo »
How do I define a display event ?
Can not find such a sevice on event tab.
Thx Udo
Events tab > Select Service [Display], Select Event Type and Save
Select Standard Message (from the display option list, what you were using prior to factory reset should show in list)
Templates (including display / .dsp files) live in the \\your.mb.pro.ip\templates folder, Display files have an extension .dsp
Also just check your Display Control setting on the System>Administration tab
Also be aware that continuously running the oled display will eventually cause screen burn-out. If you can get the same information via a different event then all the better.
