How to enable Weather Dashboard. **solved**
chrysnic
Post by chrysnic »
I have a Meteobridge Pro and I have just installed the September 7, 2022 release of the software.
However, there is no "Weather Dashboard" tab under "Live Data", as shown in the screenshot accompanying the new release on the Release Log on the main website:
https://www.meteobridge.com/wiki/index.php/Forum
Specifically, I would like to access the Aurora Light Dashboard.
What do I have to do to enable this tab?
I would appreciate any help,
chrysnic
Gyvate
Re: How to enable Weather Dashboard
Post by Gyvate »
Same observation here.
My MB Pro downloads 5.4 14812 from September 7th, 2022, but no dashboard option available.
So far the W34 dashboard was for the RPi only - but my RPi refuses to download the 7-Sep-2022 upgrade, only downloads the 20-Aug-2022 upgrade (2840). Several reboots didn't change that.
So difficult to tell if at least with MB on RPi the second dashboard option (W34 Aurora simple) is available.
MB Pro not showing the Weather Dashboard option at all under the [Live data] tab
NanoSD showing [Weather Dashboard] with both Weather 34 & Aurora dashboard options
zakos52
Post by zakos52 »
My RPi refuses to download the NEW 9-Sep-2022 upgrade, only downloads the 20-Aug-2022 upgrade (2840). Several reboots didn't change that.
So RPi not showing the Aurora Dashboard option at all under the [Live data] tab.
The bug was not fixed!
Omitting the RPI versions was fixed in just released update.
woolfg
Re: How to enable Weather Dashboard. **solved**
Post by woolfg »
Still not showing on Meteobridge Pro Red after updating this morning
Graham
woolfg wrote: Sat Sep 10, 2022 10:59 am Still not showing on Meteobridge Pro Red after updating this morning
Graham
Same here, can also confirm MB Pro red (5.4 /14816 / Sep 10, 2022) shows no Weather Dashboard under the Live Data tab.
NanoSD (5.4 / 4287 / Sep 10, 2022) does show Weather Dashboard tab and both dashboard options
Meteobridge PRO does not provide the RAM Envelope needed for PHP which is underneath the internal Weather34 and Aurora Dashboard.
Therefore, only NANO SD and RPI provide this option. Sorry for the wrong advertising on the release list, which I also corrected.
jmontamat
Post by jmontamat »
admin wrote: Sat Sep 10, 2022 12:40 pm Meteobridge PRO does not provide the RAM Envelope needed for PHP which is underneath the internal Weather34 and Aurora Dashboard.
Good morning, there is an excess of API Key Usage too often, it should be every 30 minutes or more.
Gyvate
Post by Gyvate »
with build 2841 the simplfied Aurora dashboard is now working (after completing the setup inside W34-Aurora, e.g. API keys) in parallel to the "old" W34 dashboard which was upgraded from 8.34 to 9.34.
With the download of 2841 also some php (index.php) and data files of the "old" W34 dashboard were modified, deleted, overwritten.
Luckily I had a backup 8).
Gyvate
Post by Gyvate »
there is also a version with a white background - click on the lamp / sun icon ...
