hello,
MB nano, GW1100 set as station#2
soil moisture and soil temp works fine but I can not see the raw sensor data of the leaf wetness (connecet to channel#1)
tried all combinations also on other channels but without success
what is wrong?
mant thanks in advance for any comments
HELP: ecowitt leaf wn35 sensor. **solved**
- meteoesine
- Fresh Boarder
- ScreenShot01167.jpg (12.25 KiB) Viewed 1057 times
- ScreenShot01166.jpg (14.86 KiB) Viewed 1057 times
- Screenshot_20221026_114816_com.ost.wsview.jpg (327.82 KiB) Viewed 1057 times
Re: HELP: ecowitt leaf wn35 sensor
using MB on RPi 5.5 build 2879
my WN35 Leaf wetnet sensor channel #1 is missing too
- but it is available in the Ecowitt Gateway API (aka GW1000 API) response (see below)
Looks like Boris didn't have a test sensor yet and his GW1000 driver is not reading the API response for the WN35 properly:
0xFF 0xFF 0x27 0x00 0x96 0x01 0x00 0xC8
0x06 0x39 0x08 0x26 0xE0 0x09 0x28 0x03
0x02 0x00 0x44 0x07 0x59 0x0A 0x00 0x77
0x0B 0x00 0x00 0x0C 0x00 0x00 0x15 0x00
0x00 0x00 0x00 0x16 0x00 0x00 0x17 0x00
0x2A 0x00 0x78 0x4D 0x00 0xAF 0x51 0x00
0x82 0x4E 0x00 0x7D 0x2C 0x41 0x2E 0x40
0x30 0x3E 0x32 0x2B 0x1A 0x00 0x40 0x22
0x4C 0x1B 0x00 0x5A 0x23 0x52 0x1C 0x00
0x43 0x24 0x58 0x1D 0x00 0x5B 0x25 0x4F
0x1E 0xFF 0x54 0x1F 0x00 0x57 0x27 0x45
0x20 0x00 0x39 0x28 0x4B 0x59 0x00 0x62
0x00 0x00 0x00 0x00 0x61 0x63 0x22 0x26
0x5E 0x60 0x11 0x19 0x00 0x0C 0x0E 0x00
0x00 0x10 0x00 0x00 0x11 0x00 0x02 0x12
0x00 0x00 0x01 0xDB 0x13 0x00 0x00 0x1A
0x23 0x0D 0x00 0x00 0x70 0x00 0xD3 0x34
0x00 0x61 0x00 0x9D 0x00 0x55 0x00 0x96
0x02 0xB1 0x02 0xFF 0x06 0x72 0x04 0xC4
the WN35 sensor markers/identifyers are 0x72 thru 0x79
The actual WN35 CH1 reading is 4% visible in the console, WS View Plus and the ecowitt.net dashboard.
I guess the pest controller needs to do some job to remove the bug
I had a look into the code and sensor 0x72 is defined there. So I am interested to get remote access to a system that has this 0x72 sensor, as this would give me the chance to debug.
look up your mail - @smartbedded.com
just released version should have this fixed.
yep
- it appears now as Outdoor #40 in the live raw data list - and as thx!40hum in the min/max list (x=0, 1, 2: station number)
