PRO2 sshpass error of SFTP upload. **solved**
cohenwb
Post by cohenwb »
I just bought a meteobridge PRO2 and am trying to upload to an SFTP server.
However, the test-SFTP fails with the following error:
"Error: SFTP test upload failed: sshpass: Failed to run command: No such file or directory"
The event itself is configured as follows:
Software version is Meteobridge 5.7 (Aug 11 2023, build 4133), FW 1.3 on a PRO2
The server is running SFTPGO v2.5.4, the logging does not show any sign of a (failed) incoming connection.
Any advice?
cohenwb
Re: PRO2 sshpass error of SFTP upload
Post by cohenwb »
Still looking for a solution. @admin?
Sorry, SFTP was missing on MB PRO2 distribution. Thanks for spotting this.
Just released update should do fine now.
cohenwb
Re: PRO2 sshpass error of SFTP upload. **solved**
Post by cohenwb »
admin wrote: Sun Sep 03, 2023 2:11 pm Sorry, SFTP was missing on MB PRO2 distribution. Thanks for spotting this.
Thank you.
I have installed: Meteobridge 5.7 (Sep 3 2023, build 4145), FW 1.3
The "test upload" now works, and the testfile is created on the server. I also see the login in the server logs.
The upload from normal data however still does not work.
If i trigger it manually it gives the following output:
I've tried different export files and different destination paths.
I see no login attempt in the server logs.
So there still might be an issue in the firmware?
Is there any logging I can provide from the terminal/SSH?
Yes, you are right. I overlooked a code portion that also needs to be updated. It should be fine with just released update.
cohenwb
Post by cohenwb »
Seems to be working now. Thanks
