Davis Weatherlink Cloud as a virtual weather station 5.7 version
alexvanuxem
Post by alexvanuxem »
Yesterday I tried the new feature in the 5.7 firmware: Weatherlink Cloud as a virtual weather station.
In the live data the only data I get is outdoor temp and pressure.
Nothing else.
A very nice idea, but still needs some tweaking though.
Especially because most of us have besides an ISS, leaf and soil stations, and air quality sensors.
thanks
Re: Davis Weatherlink Cloud as a virtual weather station 5.7 version
Outdoor temp & Pressure only? Nothing else? No wind speed, direction, rainfall or humidity as a basic setup?
alexvanuxem
no, that's all I got.
My Davis is a Vantage Pro 2, UV + solar, (ISS)+ soil leaf station 4 sensors, 2 airlinks (indoor outdoor).
I attached a data download file fyi from weatherlink.
Sint-Katelijne-Waver_Station_Veronique_18-9-23_00-00_1_Day_1695053207_v2.zip
(79.27 KiB) Downloaded 183 times
alexvanuxem
also I forgot to mention: I have a weatherlinklive, the old console and the new console,
maybe the MB plugin lacks also the DID number?
cheers
I will take care, when back from vacation next week. As said, it is still beta and in testing.
alexvanuxem
many thx! where I said only outdoor data apearing, I meant 'indoor + pressure'.
grtz
a
Checked with my setup and data coming in fine via RF (station 0), WLL (station 2), and the new Weatherlibk Cloud API (station2). I have a vue ISS on transmitter ID #1 and a PRO2 PLUS ISS on transmitter ID #3.
logger (02.10.2023 10:47:47): data logger (version 5.4, build 4236) started.
logger (02.10.2023 10:47:49): connect station 0 (Meteostick Vantage via serial).
logger (02.10.2023 10:47:49): connect station 1 (Davis WLL via SW Driver).
logger (02.10.2023 10:47:49): connect station 2 (Davis WL-Cloud via SW Driver).
logger (02.10.2023 10:47:49): connect station 9 (System Data via Plug-in).
logger (02.10.2023 10:47:51): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (02.10.2023 10:47:51): services paused.
logger (02.10.2023 10:47:58): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (02.10.2023 10:47:58): station 0 (Meteostick Vantage), transmitter 3 registered as ISS
logger (02.10.2023 10:47:58): station 0 (Meteostick Vantage), debug off
logger (02.10.2023 10:47:58): station 0 (Meteostick Vantage), verbose off
logger (02.10.2023 10:47:58): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (02.10.2023 10:47:58): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (02.10.2023 10:47:58): station 0 (Meteostick Vantage), filter on
logger (02.10.2023 10:47:58): station 0 (Meteostick Vantage), rx threshold set to -90db
logger (02.10.2023 10:47:58): station 0 (Meteostick Vantage), listening to tx 1 3
logger (02.10.2023 10:47:58): station 0 (Meteostick Vantage), bandwidth narrow
logger (02.10.2023 10:47:58): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (02.10.2023 10:48:45): sensors are now providing data.
logger (02.10.2023 10:48:45): services started.
Bildschirm­foto 2023-10-02 um 13.14.25.png (210.54 KiB) Viewed 2648 times
@alexvanuxem: When you send the WL Cloud API credentials you have inserted at "V2 Key+Secret" to "info(at)meteobridge.com" I can try reading data from there and check why the returning data is somehow not correctly interpreted by Meteobridge.
alexvanuxem
mail sent
latest update should fix most of the issues.
