MB AURORA - Templates not Changing (VM). **solved**
AA5H_AX088
Post by AA5H_AX088 »
Boris, or whoever:
I cannot get the templates changed. In particular, in Template 7, I have set up the parameters wanted and in the positions desired > hit 'Save' > 'refresh' > But all the positions and parameters return to the defaults. The data and readings work fine, but are not in the positions I set up.
Oddly enough, Template 1, which I did not select, changed according to my selections!
I'm sure I'm doing something stupid, so please advise.
Im Virtualized on ProxMox, version info below:
Screenshot 2025-05-16 221104.png (20.33 KiB) Viewed 6831 times
Brian
(AA5H)
Re: MB AURORA - Templates not Changing (VM)
The settings menu for Aurora is divided into sections regarding the themes 1-9. You have to make sure to select the widgets for the theme you are looking for. It can be a bit confusing before getting used to it.
Or do you mean something else?
AA5H_AX088
Boris:
Since the interface is visual, let me post screenshots of how I'm configuring. I have little doubt that I'm doing it incorrectly, so please point out my error.
1. Set Desired Template: #7 with Dark Theme:
Screenshot 2025-05-17 213223.png (309.05 KiB) Viewed 6795 times
2. Choose Widgets:
Screenshot 2025-05-17 212320.png (84.85 KiB) Viewed 6795 times
3. Choose Optional Template#7 Widgets
Screenshot 2025-05-17 212425.png (155.97 KiB) Viewed 6795 times
4. SAVE - Refresh - Return to Dashboard
5. Displayed widgets are not the same as selected (For Example, Davis AQI should appear in the top row)
Screenshot 2025-05-17 214512.png (210.78 KiB) Viewed 6795 times
Again, as always, thank you in advance for your assistance.
Brian, AA5H
Hello
Boris has requested I TAKE a look , the theme unfortunately in the top row is fixed so a long overdue of highlighting this is required however I can if required provide a solution just by a simple modification of the updater file all I need is your preference of where you would like the Davis AirLink module.in the screenshot I've used position 3 top row . don't ask for the middle row as the CSS to accommodate the wind module is critical and best not disrupt that area so you choose any position in top row .
sample SCREENSHOT below
Brian (G7LIJ *NOT QRV) :D
so it would look like this so no hard coding just use the setup screen.think thats easier way making universal for everyone no point in getting involved in individual modifications because any future simple update would possibly overwrite and keeps it simple :-) ..will forward necessary files to Boris if he ok and understands it then he provide the update via admin panel/screen.
have a nice weekend Brian..
Screenshot at May 18 17-11-27.png (132.91 KiB) Viewed 6763 times
Screenshot at May 18 17-00-41.png (251.06 KiB) Viewed 6768 times
So this is what I put to Boris to approve
added the top 4 modules in theme 7 has options also adding additional options to the bottom 4
see below for clearer picture :-)
hope thats satisfactory
brian
AA5H_AX088
Brian........ No worries, I thought I was doing something wrong.
If I understand you correctly, there is a coding and/or CSS issue with the templates, which Boris will fix in an upcoming release. Correct?
If so, I will wait for the fix. There is no sense in changing my template if a fix is coming down the road.
73's, Brian (AA5H)
Sorry, tasks just queue up here a bit. Brian was so kind to propose a fix to me, which I will need to apply. Will be done in the next days...
