Meteobridge PRO / irregular restart
Goethe2025
Post by Goethe2025 »
For a few weeks now, my Meteobridge PRO has been restarting itself and irregularly, and now several times a day. This never happened before; I've always had stable performance. The only change: the device is connected via Wi-Fi instead of LAN.
Firmware: Meteobridge 6.2 (Jun 17 2025, build 15584), FW 1.4
What can I do?
Screenshot 2025-06-18 095648.png (43.25 KiB) Viewed 6792 times
Re: Meteobridge PRO / irregular restart
Is WiFi Antenna connected correctly? Does it return to stable, when connected via Ethernet?
Goethe2025
I will test it
You might also give me remote access to allow me to check some things directly. please mail credentials to "info(at)smartbedded.com"
Goethe2025
Thank you, they are out by e-mail
Goethe2025
It has now remained stable on the LAN and is now connected to the WLAN again, but with the network adapter in the left port. A new power adapter has been ordered.
Goethe2025
Replaced the power supply yesterday and so far 19 hours without rebooting, it seems that the power supply was the cause (only in connection with WLAN).
Thanky you Boris :)
Goethe2025
Now the same behavior occurs again, today already 3 x restart ....
Had a look at the system details. There is nothing special, no RAM shortage, no massive process load, no WLAN (which can do restarts when antenna not connected correctly), no storage issues. I am a bit clueless. A faulty power connector is my last guess.
