Just to share a strange behavior I've just got with the last meteobridge build 6.3 with an RPI setup
after having upgraded to the last 6.3 build 2 days ago, I've discovered that the meteobridge's RPI was acting as a DHCP server giving it's own IP@ as a DNS server and Default gateway
the fact my local network was really impacted (no DHCP guard protection here), I've quickly rollback to meteobridge 6.2 and did not took any time to troubleshoot anything.
this is why I'm not fully confident with what I'm arguing here
this is just FYI Boris
what I can say is 2 x laptop was impacted after some hours after this upgrade
Meteobridge 6.3 acting as a DHCP server
Re: Meteobridge 6.3 acting as a DHCP server
I am rather sure that it does not act as a DHCP server when connected ONLY via WLAN or ONLY via LAN with your network, if you do both in parallel (which is not intended) you might have problems.
When you share your Meteobridge network settings I can have a look.
hello
here are and was the network setting used
https://ibb.co/XZJBRPVG
and yes I confirm it was acting as a DHCP server with this new version and generated a downtime on my local network
current version
Platform: Raspberry Pi 3 Model B Rev 1.2
RAM: 941 MB total, 526 MB free (44% used)
Storage: WD SLC, 14.6 GB total, 11.7 GB free (20% used, 33.4 yrs)
SW Version: Meteobridge 6.2 (Oct 14 2025, build 4128), FW 1.3
cheers
current version
cheers
I checked with my PRO2 and there is neither a DHCP server process running nor any DHCP server enablement in the settings when I use a static IP address as done in your example setup.
Can you please send content of "/etc/config/dhcp" and output of "ps w" so I can check settings of your RPI.
