service settings Meteobridge Nano SD. **solved**
can anybody remind me how to display my service settings ?
I got an "empty"screen when displaying the tab.
Re: service settings Meteobridge Nano SD
You see settings there when you have "Events" programmed. Why do you have two "Events" tabs. Something looks borked.
- event.jpg (87.15 KiB) Viewed 1184 times
I have 13 events.
In the first event tab there are 10 and then 3 others in the second tab.
At the bottom of the first event tab there is a button "next events" that jumps tot the second event tab.
I have 13 events.
Well, that tab is where they are supposed to be AFAIK. Do a reboot or something.
hm reboot does not help
Maybe try different version on a re-boot?
- Ver.jpg (64.25 KiB) Viewed 1166 times
in version Meteobridge 6.1 (Apr 30 2025, build 5059), FW 1.4, I have the screen back, where I can uncheck the
"hide credentials" mark.
In version 6.2 and current 6.3 it does not show.
I hope the developer will read this thread and come up with a solution.
Kind regards
Kind regards
Seems unique to Nano. My RPi on 6.3 is fine.
Bit of an odd ball one? Have never seen that as an option and don't see any issues in several Nano/NanoSD running various 6.3 version from Dec 2025? Do not see this in MBPro or Pro2 either
The only reference I can see to this is on November 5, 2018 where there was an option added which
"allows to hide email/ftp/mysql/twitter/sms credentials within "Services" tab."
can I contact the admin about this ?
Or how can I bring this under his/her attention ?
(I cannot pm the admin via "the team")
when you provide me a remote login, I can have a look. Please send credentials to "info(at)meteobridge.com".
fixed with just released update.
Re: service settings Meteobridge Nano SD. **solved**
Thank you very much for solving the problem and your support
