No data weatherstation after update 6.3 (Mar 25 2026)
BeBe
Post by BeBe »
After an update (reboot) of the Meteobridge PRO2 to 6.3 (Mar 25 2026), the values ​​from the Davis weather station are no longer displayed. Neither is the internal temperature. After startup, the orange LED flashes for approx. 10 minutes and then stays lit constantly. The red LED does not light up, nor does it light up for Live Data. This scenario occurs after every startup.
This is also the case with my previous MB (red).
What is going wrong here?
Scherm­afbeelding 2026-03-30 om 10.04.00.jpg (249.28 KiB) Viewed 575 times
Scherm­afbeelding 2026-03-30 om 10.05.03.jpg (173.79 KiB) Viewed 575 times
Re: No data weatherstation after update 6.3 (Mar 25 2026)
To confirm any issues with the latest version have you tried downgrading to the last version?
Also is there a Mar 25, 2026 release, as the last version in the release log is February 25, 2026?
BeBe
Post by BeBe »
I tried a previous release, but this also gives no data, neither on the PRO nor the PRO (red).
Regarding MAR 25 2026 see attachment
Scherm­afbeelding 2026-03-30 om 13.41.58.jpg (15.84 KiB) Viewed 558 times
Ok just updated a Pro (red) and see the latest version is 6.3 (15642), March 25. 2026 which continues to work fine via RF from a Davis ISS.
Have you tried changing the Sensitivity to may -80db? What is your distance Pro2 to ISS?
BeBe
Post by BeBe »
I followed your advice and set the sensitivity to -80, then restarted, after which all data from the ISS were displayed again. :D
The distance to the ISS is approximately 16 meters and I am using a WH-MBpro-GP Ground plane antenna for MBpro SKU WH-MBpro-GP.
Signal strength / distance is a key requirement with the Pro as there are limitations even with different antenna systems where as a Nano has the same signal capability as the standard Davis console. I basically include a Davis repeater where the ISS and Pro are at distance.
Also just updated a Pro2 to FW 6.3 (Build 6256) Mar 25, 2026 without any issues.
