Ecowitt GW1000 and Davis Wind Station - sensor mapping
baobab
Post by baobab »
I have the following setup:
- Primary station: GW1000 receiving data from WS90
- Station1: Vantage USB Serial connected to Vantage Vue Console configured to Sta#2:Wind (all other stations set to off)
Problem: http://192.168.1.122/cgi-bin/livedata.cgi results in the following:
20260501020628 th0 20.3 17 -5.6 0
20260501020628 thb0 21.3 26 1.0 911.0 911.0 -1 0
20260501020628 wind0 201 0.9 0.9 20.3 0
20260501020628 sol0 39 0
20260501020552 uv0 0.0 0
20260501020558 rain1 0.0 0.0 0.0 0
20260501020630 wind0 155 0.4 1.3 20.3 0
20260501020602 thb0 22.4 28 3.0 910.4 1012.3 0 1
20260501020628 data10 16.00 0
20260501020628 data11 0.04 0
20260501020628 data12 1.00 0
20260501020628 data13 10.00 0
20260501020628 data15 113.00 0
20260501020628 t9 50.5 0
20260501020628 data16 0.00 0
As you can see, wind0 is duplicated (as is thb0).
The live data monitor differentiates the two wind inputs:
# Sensor Signal Metric Data Imperial Data
0 Outdoor 13 sec 19.8°C 18% (dew-5.2°C,hi19.8°C,wb8.6°C) 67.6°F 18% (dew22.6°F,hi67.6°F,wb47.4°F)
0 Indoor 1 sec 21.2°C 26% 910.8hPa (910.8hPa) 70.2°F 26% 26.90inHg (26.90inHg)
0 Wind 1 sec 2.1m/s (avg 2.1m/s) 182° S 4.7mph (avg 4.7mph) 182° S
0 Solar 13 sec 28W/m² 28W/m²
0 UV 13 sec 0.0uvindex 0.0uvindex
0 Rain #1 7 sec rate 0.0mm/h rate 0.00in/h
1 Wind 1 sec 0.4m/s (avg 0.9m/s) 0° N 0.9mph (avg 2.0mph) 0° N
1 Indoor 19 sec 22.2°C 28% 1012.1hPa (910.2hPa) 72.0°F 28% 29.89inHg (26.88inHg)
9 Data #10 1 sec 2% system load 2% system load
9 Data #11 1 sec 0.3h uptime 0.3h uptime
9 Data #12 1 sec 1% data store usage 1% data store usage
9 Data #13 1 sec 11% RAM usage 11% RAM usage
9 Data #15 1 sec 107 processes 107 processes
9 CPU T #9 1 sec 50.5°C 122.9°F
9 Data #16 1 sec 0sec since last data 0sec since last data
I have sensor mappings configured as follows:
Physical Sensor------Logical Sensor------Meaning
wind0!0avgwind------wind0avgwind------average wind speed
wind0!0chill------wind0chill------wind chill
wind0!0dir------wind0dir------wind direction
wind0!0wind-----wind0wind------wind speed
wind1!0avgwind------wind1avgwind------extra average wind speed #1
wind1!0chill------wind1chill-------extra wind chill #1
wind1!0dir------wind1dir------extra wind direction #1
wind1!0wind------wind1wind------extra wind speed #1
Why are there two wind0 data sets vs the expected wind0 and wind1? Am I doing something wrong and how can I fix this problem?
Thank you,
Baobab
Re: Ecowitt GW1000 and Davis Wind Station - sensor mapping
looks like the livedata.cgi is not multi-station ready.
Why don't you request the data from the sensors you are interested in via template.cgi? This is the recommended way.
