Just setting up a Pro2. on Aurora, it's showing the "indoor temp" is 112 degrees F! The Davis Console says 82. Should I be forwarding data from the console? Is the temp I'm seeing the internal temp of the Pro2?
TIA
Indoor temp is 112 degrees F! Help Please
Re: Indoor temp is 112 degrees F! Help Please
Indoor temp 112 Deg F is the temp inside the PRO2 (Box Climate) and not Indoor temp (as such). 112 Deg F is around 44 Deg C and fairly normal, Box (Inside) Temp will/can get hotter than that. Console temp of 82 Deg F (~ 28 Deg C) is more an Inside Temp and even that will be up by a few degrees due to heating within the console.
