Skyvex as an HTTP Event target (WU format) — does this config look right?
mstrommer
Post by mstrommer »
Hi everyone,
I run Skyvex (skyvex.org), a free platform for weather station data — dashboard, charts, warnings and embeddable widgets. I'm posting as the operator, and I'm not here to advertise: I'm stuck on something and this seems to be the place where people actually know the answer.
Skyvex accepts the Weather Underground protocol, so everything Meteobridge needs is already in place on our end. The endpoint is live, it takes ID and PASSWORD as credentials, it understands dateutc=now, and on success it replies with the plain text success — so that string can go straight into the success field.
What I don't have is any hands-on experience with the other half. I don't own a Meteobridge. I put the following URL for Services → HTTP Event together from the wiki and a published template, but I have never seen it run:
https://api.skyvex.org/weatherstation/u ... raw&tempf=[th0temp-act=F.1:--]&humidity=[th0hum-act.0:--]&dewptf=[th0dew-act=F.1:--]&windspeedmph=[wind0wind-act=mph.1:--]&windgustmph=[wind0wind-max10=mph.1:--]&winddir=[wind0dir-act.0:--]&baromin=[thb0seapress-act=inHg.3:--]&dailyrainin=[rain0total-daysum=in.2:--]&rainin=[rain0total-sum60=in.2:--]&rainratein=[rain0rate-act=in.2:--]&solarradiation=[sol0rad-act.1:--]&UV=[uv0index-act.1:--]
Three things I'd be grateful to have checked:
Are the selectors right? I'm least sure about rain0total-sum60 for the last hour of rain and wind0wind-max10 for the gust — those were guesses on my part.
Are the converters after the equals sign (=F, =mph, =inHg, =in) the sensible choice for the WU format?
Is -- a safe placeholder here? On our side it is: Skyvex discards non-numeric values, so a sensor that drops out won't be stored as a false 0. I'm asking about the Meteobridge end.
An account is free, and the station ID and password appear in the settings right after signing up. If anyone feels like trying it, I'd very much appreciate the feedback and will correct the instructions accordingly. Current version of the instructions: https://skyvex.org/setup-guide#meteobridge
There's a live dashboard running on the front page if you want to see where the data ends up — tiles can be rearranged, renamed and shared individually, and there's a dark mode. Curious what you make of it.
Thanks in advance, Michael
SkidMark
Re: Skyvex as an HTTP Event target (WU format) — does this config look right?
Post by SkidMark »
Hello Michael,
I copied the URL from your instructions page and one thing I don't see is the Outside Dew Point and currently no rain to test the rain values.
Other than that all the other entries are showing up on my dashboard.
Edit: I see the Outside Dew Point now, I was looking for it in it's own window.
Looks great!
Mark
I am happy to include skyvex to the list of supported weather stations, which makes it very easy for users to support this network.
All I need to do is to direct the WU data to this URL?
https://api.skyvex.org/weatherstation/updateweatherstation.php
Which is the shortest send interval that is accepted?
Could you please setup a test account and send info to "info(at)meteobridge.com"?
mstrommer
Post by mstrommer »
Thanks Boris — I have just sent you an e-mail to info(at)meteobridge.com with the test account and the answers to your questions. There is a confirmation link in a separate mail from the system that activates the account; one click and you are in. Happy to answer anything else here or by mail.
I just release skyvex support as a regular Meteobridge weather network. Please give it a test drive.
