[Plugin] Purpleair AQI Calculations Plugin
azchrisf
Post by azchrisf »
[Release] Meteobridge AQI Plugin v1.0.3
I created a User-Defined Plugin for Meteobridge that reads PM2.5 data from an existing Purpleair station, and publishes calculated U.S. EPA Air Quality Index values as a separate Meteobridge station.
Features
The plugin provides:
  • Instantaneous PM2.5 AQI-equivalent
  • EPA particulate NowCast AQI
  • Current PM2.5 concentration
  • NowCast PM2.5 concentration
  • Numeric EPA air-quality category
  • Optional EPA U.S.-wide PurpleAir correction
  • Stale and invalid sensor-data rejection
  • Plugin health and error reporting
  • Persistent history for NowCast calculations
  • EPA 2024 PM2.5 AQI breakpoints
This is my setup (Purpleair is Station 1 and the AQI Plugin is Station 4 - granted not very much dust out at the moment this was taken):
The instantaneous AQI-equivalent becomes available with the first valid PM2.5 sample. EPA NowCast requires sufficient hourly history and normally appears after approximately one to two hours.
Supported Meteobridge Platforms
This plugin was developed under Meteobridge VM edition.
This release requires a Meteobridge platform with a local scripts directory and writable local storage.
Supported platforms:
  • Meteobridge PRO, including the original red and black models
  • Meteobridge PRO2
  • Meteobridge NANO SD
  • Meteobridge Raspberry Pi
  • Meteobridge VM
This package does not support:
  • Original TP-Link, D-Link, or other router hardware flashed with Meteobridge
  • Meteobridge NANO without the SD storage option
Although some older platforms can download a User-Defined Plugin from a URL, this is intentionally a two-file local plugin. It requires a separate configuration file and writable storage for NowCast history, status information, and logs.
There is no single-file or URL-only edition.
Installation
No installer, service, cron job, or /root/datafeed modification is required.
You can download the code at https://github.com/AZChris83/MBPurpleAirAQI
Make configuration adjustments as needed and detailed below in meteobridge-aqi.conf FIRST
Then, copy these two files into the Meteobridge scripts directory:
meteobridge-aqi.plugin
Then:
  1. Open the Meteobridge Weather Station configuration.
  2. Add an additional station.
  3. Select User-Defined Plugin as the station type.
  4. Select meteobridge-aqi.plugin.
  5. Save the configuration.
  6. Restart the station process if requested.
The package includes complete installation, configuration, troubleshooting, updating, and removal documentation.
PM2.5 Source Configuration
For a PurpleAir connected as Meteobridge Station 1:
SOURCE_STATION=1
PM25_SENSOR="air1pm"
The plugin resolves this to:
air1!1pm
On the standard Meteobridge mapping, air1!1pm is PM2.5. The air1!0pm channel is PM10 or the default particulate channel and should not be used for PM2.5 AQI.
A fully qualified sensor name can also be entered directly:
PM25_SENSOR="air1!1pm"
Output Sensors
The plugin publishes:
  • data0num: Instantaneous AQI-equivalent
  • data1num: EPA NowCast AQI
  • data2num: AQI category code
  • data3num: Current PM2.5 concentration
  • data4num: NowCast PM2.5 concentration
  • data5num: Plugin status code
The outputs belong to the User-Defined Plugin station. For example, when the plugin is Station 4, its physical sensor names are data4!0num through data4!5num.
Category codes:
0 = Good
1 = Moderate
2 = Unhealthy for Sensitive Groups
3 = Unhealthy
4 = Very Unhealthy
5 = Hazardous
Status codes:
0 = Healthy
1 = PM2.5 source missing, invalid, stale, or unreachable
2 = Humidity unavailable while PurpleAir correction requires it
3 = Configuration or storage error
The plugin emits a status record immediately at startup so Meteobridge does not disconnect it while waiting for the first PM2.5 query.
EPA 2024 PM2.5 Breakpoints
PM2.5 µg/m³      AQI         Category
0.0 to 9.0       0 to 50     Good
9.1 to 35.4      51 to 100   Moderate
35.5 to 55.4     101 to 150  Unhealthy for Sensitive Groups
55.5 to 125.4    151 to 200  Unhealthy
125.5 to 225.4   201 to 300  Very Unhealthy
225.5 to 325.4   301 to 500  Hazardous
PM2.5 is truncated to one decimal place before interpolation, and AQI is rounded to the nearest whole number.
PurpleAir Correction
The optional EPA U.S.-wide PurpleAir correction is disabled by default. It should only be enabled when the selected field is raw PurpleAir PM2.5 CF=1 data.
If PurpleAir or Meteobridge has already corrected the selected value, enabling the plugin correction would apply it twice and produce an incorrect result.
Requirements
  • A supported Meteobridge platform
  • User-Defined Plugin station support
  • An existing PM2.5 sensor visible to Meteobridge
  • A local scripts directory
  • Writable local storage
  • POSIX shell and awk
  • curl or wget
  • No Python dependency
Important Limitations
The instantaneous result is an AQI-equivalent based on the latest PM2.5 measurement. It is not the official EPA 24-hour AQI.
EPA NowCast is generally the better value for representing current health conditions because it uses weighted hourly averages.
This plugin is not a regulatory monitor. Results may differ from AirNow because of sensor hardware, placement, correction methods, quality control, and averaging periods.
The plugin is released under the MIT License - AI did assist in programming this plugin FYI.
ENJOY!
paul_1055
Re: [Plugin] Purpleair AQI Calculations Plugin
Post by paul_1055 »
Very nice plugin. Thanks for sharing.
However, I had to replace the line
"$SCRIPT_DIR/meteobridge-aqi.conf" \
        "/data/scripts/meteobridge-aqi.conf" \
        "/scripts/meteobridge-aqi.conf"
with this one
        "/tmp/data/scripts/meteobridge-aqi.conf" \
Raspberry Pi 4 Model B Rev 1.1 Rev 1.1
Meteobridge 6.4 (Sep 19 2026, build 4320), FW 1.3
Regards,
Torsten
azchrisf
Post by azchrisf »
Good catch, i'll fix that. Thanks!
grwkak
Post by grwkak »
Thanks for sharing this. Works well!
Guy
Does this also work with a Davis Airlink?
The Aurora Meteobridge template already performs a similar conversion to AQI EPA, are the values comparable?
grwkak
Post by grwkak »
Does the plugin change the polling frequency of the PurpleAir? The reason I ask is that I also use Cumulus MX to monitor the PA and logging errors with the PA increased with Cumulus after adding this plugin. I think the hardware of the unit is somewhat limited so too much polling seems to be an issue.
GUy
