Customised rain gauges?
Hardware topics that do not fit in one of the other categories
Post by skyewright »
In software like WD it is possible to set offsets for various incoming values to allow a degree of calibration, e.g. if an anemometer is known to read 10% low.
Another use for this feature is to accommodate rain gauges that have been 'customised' to improve sensitivity by increasing the capture area (e.g. add a funnel to double the area, then apply a 0.5 multiplier to values arriving from the gauge before they are stored).
Does Meteohub provide a way of handling that sort of thing?
PS. I just ordered a slug, so I will be wanting Meteohub in due course now. :)
Re:Customised rain gauges?
skyewright wrote:Another use for this feature is to accommodate rain gauges that have been 'customised' to improve sensitivity by increasing the capture area (e.g. add a funnel to double the area, then apply a 0.5 multiplier to values arriving from the gauge before they are stored).
Found it in the manual now! I had looked before, but I was searching on the wrong terms. 'factor' was the magic word that got me there. :)
Ah, but what if I had a RFXCOM and more than one rain gauge - one of which had been modified?
Hi, at the moment the factor gets applied to all rain sensors.
admin wrote:Hi, at the moment the factor gets applied to all rain sensors.
I sort of guessed that.
It would be great if you could bear in mind the possibility of setting the factor at sensor level as an alternative.
I am awaiting delivery of a Slug and and an RFXCOM receiver (so I'll be wanting Meteohub too, soon :) ). In the near future I hope to have 2 rain gauges set up with that. I'd like to be able to convert one of those gauges to greater sensitivity, but keep the other as standard (as a cross reference, especially if there is a downpour that is so heavy it swamps the modified gauge).
Might that become possible?
PS. And maybe nice to allow other sensor level factors, e.g. for barometer or windspeed adjustments.
