I noticed that in the data export screen to WD there's no possibility to export UV and Solar data.
Is that a hidden option of don't it exists?
I want to know this because on my remote locatieon I use two weather stations, a Davis Vantage Pro with UV and Solar and a RFXcom receiver with a lot of OS stuff attached to it.
I noticed that version 4 has multi weather station capabilities so if MeteoHub supports the data for WD I need I don't have to run virtual weather station to double the Davis data and I can use MeteoHub to feed WD with data.
							Meteohub and Weather Display
- HeinrichH
Checking the remote....
Re:Meteohub and Weather Display
Have you looked at this alternative route for getting Meteohub data into WD?HeinrichH wrote:I noticed that in the data export screen to WD there's no possibility to export UV and Solar data.
- HeinrichH
Thanks for the tip, does WD then collecting all the data thats Meteohub is collecting? Also all the extra sensors?
Essentially WD sees a copy of all sensor readings that Meteohub collects.HeinrichH wrote:Thanks for the tip, does WD then collecting all the data thats Meteohub is collecting? Also all the extra sensors?
thb0 => Indoor temp/hum & baro
wind0 => Wind
rain0 => Rain
Other wind and rain are ignored (as WD only expects 1 of each).
th0 => Main outdoor temp/hum
th1-9 => Extra sensors (I'm not sure what would happen if you had a th10!)
I don't have a UV sensor but I believe that is also handled.
N.B. If you have temp only, then WD sees th1 and t1 as the same sensor, so keep the numbering separate in Meteohub, e.g. I have th0, th1, th3, th5, th6, t7, t7 and t9!
th0 does not conflict with thb0.
