THWR800/WMR100 trouble and upgrade question
samikki
Post by samikki »
Today I received a THWR800 water temperature sensor for my WMR100. I set it up and I can see its data in WMR100 display. However, my meteohub is not able to see it.
When I look at the raw data with "Inspect data" option, there is no mention of the THWR800. I set it up on channel 3 so I guess it should show up as th2?
Because THWR800 measures only temperature, it shows in WMR100 without hydro information, like this: 21.5 C -- %. I wonder if this affects meteohub somehow?
I found a previous thread with a same question, but I was not able to find any usable answer from that thread.
There is one thing: I am still running version 2.6 of meteohub on my NSLU2. I wonder if newer versions have a fix for this problem?
That takes me to my another question: can I upgrade the newest version of meteohub straight on top of my 2.6 or should I make intermediate upgrades? What's the recommended procedure?
Sami
Re:THWR800/WMR100 trouble and upgrade question
go to 3.1 and then to 4.2rc3.
samikki
Post by samikki »
Thank you, I was able to upgrade successfully!
But, Meteohub still cannot see my THWR800 water temperature sensor. It's not visible in the Sensors list nor in Inspect data list.
The sensor is visible in my WMR100 though.
The THWR800 is a floating sensor for WMR100 and it looks identical to THWR288.
Help?
Sami
is it a pure temp sensor?
If so, the next update might cure that.
Please send a mail to "info(at)meteohub.de". I can provide you a pre-production update so that you can verify that it solves your problem.
samikki
Post by samikki »
Yes, it's temperature only. I'll send you email.
samikki
Post by samikki »
Running rc6 now but THWR800 is still not recognized. Any ideas?
Can you give me access to your Meteohub? would need ports 22 and 7777. Please mail WAN IP to info(at)meteohub.de.
samikki
Post by samikki »
Works beautifully now - thanks!
Will this be a part of further update?
yes, of course. It will be avail for all from the next update on.
