Can i use a big USB harddisk instead of a USB stick?
Paul
Post by Paul »
I had a working NSLU2 with a 2gb harddisk in a external USB harddisk case.
This worked fine, but the harddisk started to become noisy, so i replaced it with a bigger (10GB) harddisk.
I installed version 4.3 and had it autoupdate to 4.3C. All fine but....
When i look with windows xp (using samba) I see a file called "transfer" of approx 4gb, a file called "uploades" of 1 kb and a file "weather" of approx 800Mb.
Is this correct??? Should it not be a subdirectory and not a file?
The log says:
logger (26.05.2009 20:46:56): data logger started.
logger (26.05.2009 20:46:58): connect station 0 (TE-923 via USB HID).
wmr928eval (26.05.2009 20:47:00): error while opening file /data/weather//seq-min1 for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:48:00): error while opening file /data/weather//seq-min1 for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:49:00): error while opening file /data/weather//seq-min1 for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:50:00): error while opening file /data/weather//seq-min1 for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:50:00): error while opening file /data/weather//hist-day1 for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:50:01): error while opening file /data/weather//hist-hour1 for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:50:01): error while opening file /data/weather//hist-last24h for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:50:01): error while opening file /data/weather//hist-last60m for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:50:01): error while opening file /data/weather//hist-last15m for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:50:01): error while opening file /data/weather//seq-min1 for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:50:01): error while opening file /data/weather//seq-hour1 for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:51:01): error while opening file /data/weather/thb0-min5 for writing: Not a directory: Not a directory
wmr928eval (26.05.2009 20:51:01): error while opening file /data/weather//seq-min1 for writing: Not a directory: Not a directory
logger (26.05.2009 20:51:58): child process received timeout signal (14).
logger (26.05.2009 20:51:58): data logger started.
logger (26.05.2009 20:51:59): connect station 0 (TE-923 via USB HID).
wmr928eval (26.05.2009 20:52:00): error while opening file /data/weather//seq-min1 for writing: Not a directory: Not a directory
Re:Can i use a big USB harddisk instead of a USB stick?
transfer should be a folder.
transfer folder is not vital, but this indicates that your system may have file system inconsistencies.
This is very interesting, as normally a bad USB stick is causing this kind of trouble... I start thinking of the USB files ystem interface being the root cuase for these kind of errors and not a bad USB stick. Hard to believe, but I will start thinking about that.
Paul
Post by Paul »
Thank you for trying to solve this.
By the way, i have paid for a official licence for meteohub :cheer:
To try to debug this i did the following:
-Flash the NSLU2 with the latest "meteohub-firmware-2.3.bin"
-delete all partitions that Windows XP could find on the external USB harddisk
-Connect a 256MB USB stick with "meteohub-v4.3-2GB.rar" to the bottom USB connecton
-and when disk 2 started to blink slowly, i connected the empty USB harddisk to the other USB port.
-after a while the install was ready and the NSLU2 shut down automatically.
-I than removed the USB stick and connected my Cresta weatherstation to the same USB port that previously had the 256MB installer USB stick.
-When i use my XP laptop to go to \\\\192.168.1.77\\public i see the files transfer,upload and weather. See attachment.
This seems to be reproducable.
If i can help you te better debug this (as i cannot use it right now), please tell me what you want me to do!
Best regards,
Paul
When using the two sticks method Meteohub writes a log onto the installer stick. What does the log say?
When you have a windows XP machine at hand, please try to setup USB stick with DiskImage. This is fastest and most reliable option. (please make sure to use "physical disk" mode!).
Paul
Post by Paul »
Log files: [file name=Archive.zip size=689]http://www.meteohub.de/joomla/images/fb ... rchive.zip[/file]
I will try your suggestion with DiskImage next...
Paul
Post by Paul »
And IT WORKS!!!! :cheer:
The diskimage tool seems to make the difference!
I hope my logs of the fauly situation can help you to debug it.
By the way, i'm using a 6GB harddisk and not a 10GB as
i said incorrectly in my original posting.
Paul
Post by Paul »
You have even included windchill for my cresta weatherstation now!
GREAT!!!
