temperatur sensor for freezer
Hardware topics that do not fit in one of the other categories
geiermann
Post by geiermann »
I wants to install in my freezer a temperaure sensor. Because the temperatur is -5°C or less, a normal sensor will not fit.
Doese anyone has experience with a temperature sensor in a freezer and which modell is there in use.
HeinrichH
Re:temperatur sensor for freezer
Post by HeinrichH »
This is the one I'm using in my freezer http://www.ukweathershop.co.uk/acatalog ... HC238.html
Checking the remote....
Going with lithiuam batteries might also help as they can handle low temps much better than alcaline.
rune
Post by rune »
I've got a Dallas 1-Wire DS18S20 sensor in my freezer and in my fridge. I'm using MSure (www.msure.se) to log the data. Works perfectly (I'm just missing a link between 1-Wire/MSure and Meteohub)
User Skyewright did an integration of 1wire sensor into Meteohub via Meteohub's plugin concept. Maybe you can do something similar.
