Alix/Etch updates
netsigi
Alix/Etch updates
Post by netsigi »
just checked about available Updates for the System flashed some months ago. Since I had troubles with other flash-based stuff, I wonder if somebody has some experience about this..
Actual state:
meteohub:~# sh check-upg.sh
| Available OS Updates |
Failed to fetch http://kernel-archive.buildserver.net/debian-kernel/dists/etch/Release.gpg  Could not connect to kernel-archive.buildserver.net:80 (194.39.182.145), connection timed out
E: Some index files failed to download, they have been ignored, or old ones used instead.
** Testing what packages could be upgraded: **
Reading package lists...
Building dependency tree...
The following packages will be upgraded:
   acpid (1.0.4-5 => 1.0.4-5etch1)
   apt (0.6.46.4-0.1 => 0.6.46.4-0.1+etch1)
   apt-utils (0.6.46.4-0.1 => 0.6.46.4-0.1+etch1)
   bind9-host (9.3.4-2etch3 => 9.3.4-2etch5)
   debian-archive-keyring (2007.07.31~etch1 => 2009.01.31)
   dhcp3-client (3.0.4-13 => 3.0.4-13+etch2)
   dhcp3-common (3.0.4-13 => 3.0.4-13+etch2)
   dnsutils (9.3.4-2etch3 => 9.3.4-2etch5)
   dpkg (1.13.25 => 1.13.26)
   dpkg-dev (1.13.25 => 1.13.26)
   dselect (1.13.25 => 1.13.26)
   libbind9-0 (9.3.4-2etch3 => 9.3.4-2etch5)
   libc6 (2.3.6.ds1-13etch7 => 2.3.6.ds1-13etch9+b1)
   libc6-dev (2.3.6.ds1-13etch7 => 2.3.6.ds1-13etch9+b1)
   libc6-i686 (2.3.6.ds1-13etch7 => 2.3.6.ds1-13etch9+b1)
   libcupsys2 (1.2.7-4etch5 => 1.2.7-4+etch8)
   libdbus-1-3 (1.0.2-1+etch2 => 1.0.2-1+etch3)
   libdns22 (9.3.4-2etch3 => 9.3.4-2etch5)
   libgnutls13 (1.4.4-3+etch1 => 1.4.4-3+etch4)
   libisc11 (9.3.4-2etch3 => 9.3.4-2etch5)
   libisccc0 (9.3.4-2etch3 => 9.3.4-2etch5)
   libisccfg1 (9.3.4-2etch3 => 9.3.4-2etch5)
   libkrb53 (1.4.4-7etch6 => 1.4.4-7etch7)
   liblwres9 (9.3.4-2etch3 => 9.3.4-2etch5)
   libpam-modules (0.79-5 => 0.79-5+etch1)
   libpam-runtime (0.79-5 => 0.79-5+etch1)
   libpam0g (0.79-5 => 0.79-5+etch1)
   libsasl2 (2.1.22.dfsg1-8 => 2.1.22.dfsg1-8+etch1)
   libsasl2-2 (2.1.22.dfsg1-8 => 2.1.22.dfsg1-8+etch1)
   libssl-dev (0.9.8c-4etch3 => 0.9.8c-4etch9)
   libssl0.9.8 (0.9.8c-4etch3 => 0.9.8c-4etch9)
   libvolume-id0 (0.105-4 => 0.105-4etch1)
   linux-headers-2.6.24-etchnhalf.1-486 (2.6.24-6~etchnhalf.6 => 2.6.24-6~etchnhalf.8etch3)
   linux-headers-2.6.24-etchnhalf.1-common (2.6.24-6~etchnhalf.6 => 2.6.24-6~etchnhalf.8etch3)
   linux-image-2.6.24-etchnhalf.1-486 (2.6.24-6~etchnhalf.6 => 2.6.24-6~etchnhalf.8etch3)
   locales (2.3.6.ds1-13etch7 => 2.3.6.ds1-13etch9)
   locales-all (2.3.6.ds1-13etch7 => 2.3.6.ds1-13etch9+b1)
   login (4.0.18.1-7 => 4.0.18.1-7+etch1)
   ndiswrapper-utils-1.9 (1.28-1 => 1.28-1+etch1)
   ntp (4.2.2.p4+dfsg-2 => 4.2.2.p4+dfsg-2etch3)
   ntpdate (4.2.2.p4+dfsg-2 => 4.2.2.p4+dfsg-2etch3)
   openssl (0.9.8c-4etch3 => 0.9.8c-4etch9)
   passwd (4.0.18.1-7 => 4.0.18.1-7+etch1)
   perl (5.8.8-7etch3 => 5.8.8-7etch6)
   perl-base (5.8.8-7etch3 => 5.8.8-7etch6)
   perl-modules (5.8.8-7etch3 => 5.8.8-7etch6)
   udev (0.105-4 => 0.105-4etch1)
   vim-common (7.0-122+1etch3 => 7.0-122+1etch5)
   vim-tiny (7.0-122+1etch3 => 7.0-122+1etch5)
49 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 5833kB/65.4MB of archives.
After unpacking 2269kB of additional disk space will be used.
Get:1 http://security.debian.org etch/updates/main libssl-dev 0.9.8c-4etch9 [2095kB]
Get:2 http://security.debian.org etch/updates/main libssl0.9.8 0.9.8c-4etch9 [2722kB]
Get:3 http://security.debian.org etch/updates/main openssl 0.9.8c-4etch9 [1016kB]
Fetched 5833kB in 10s (551kB/s)
Download complete and in download only mode
Ettershaus
Re:Alix/Etch updates
Post by Ettershaus »
It's realy easy ;-)
The Server with the kernel-packages (http://kernel-archive.buildserver.net/d ... elease.gpg) ist noch accessable at the moment.
netsigi
Post by netsigi »
Super Tip!!
Not really! after apt-get upgrade the System was unbootable.
Worse:
Reflashed with 4.5. Had seven backups of settings, latest backup7: Format error, backup6: format error.
Backup5 ok.
Next problem.
System ID has changed.. f...
I like Meteohub one way, but I hate Systems that are not consistent the other.
netsigi
Post by netsigi »
Quoting myself again.
Fresh install of ALIX-Image Today is the 5.october. 2009
Program Versions:
meteohub:/home/meteohub# thttpd -V
thttpd/2.25b 29dec2003
meteohub:/home/meteohub# openssl version
OpenSSL 0.9.8c 05 Sep 2006
meteohub:/home/meteohub# uname -a
Linux meteohub 2.6.24-etchnhalf.1-486 #1 Mon Oct 13 06:47:02 UTC 2008 i586 GNU/Linux
This is simply careless... All this packets had massively problems.
thttpd-2.25b is the newest version avail. If you have sources of newer versions, please let me know.
open ssl is used for computation of hashes for some weather networks and for activation code handling. Nothing you should worry too much about.
And yes, the used etch'n'half kernel is a year old.
As posted to your similar remark in another forum, Meteohub is a appliance with a very limited scope of provided services, like your PVR, NAS, MediaPlayer, WebCam, Print-Spooler and all the other devices in your LAN. You should newer place this directly into the Internet. But having that in your LAN behind a router/firewall I can hardly see a tangible security threat there.
