Internet access
kerry645
Internet access
Post by kerry645 »
I have connected to my WMR100 and all the sensors are reporting. In the system info I have a no Internet Access message. I also have a reboot message for the meteohub but I have rebooted several times. Any suggestions?
rune
Re:Internet access
Post by rune »
Could you please describe your Internet/LAN setup? e.g. router, switch, DHCP etc.?
What LAN settings do you have for your Meteohub?
kerry645
Re:Internet access
Post by kerry645 »
I have a Netgear router hooked to a Cable Modem. All my other computers and wireless stuff is working just fine. The meteohub is hooked up and connected as 192.168.1.77
The DHKP box is checked.
Re:Internet access
could you please post a screen dump of your "system information" page?
If gateway ip does not show a valid ip (but 0.0.0.0) then you can't gain Internet access. Have a look at a cure here: http://www.meteohub.de/joomla/index.php ... 6&catid=23
kerry645
Re:Internet access
Post by kerry645 »
MeteoHub System Information
10:50 18.10.2009
System Info
Network
Log Files
Inspect Data
Sensors
Settings
Weather Station
Dashboard
WD Live
Maintenance
Define Graphs
Manage Graphs
Setup Push Services
Graph Uploads
Weather Networks
WSWIN Data Export
WD Data Export
License
SoftwareLinux Kernel: 2.6.21.7 132 BogoMIPS, 30 MB RAM, NSLU2 (133 MHz)
MeteoHub: Version 4.4 ©2009 by Boris Pasternak, info@meteohub.de
System ID: W3uO1 activated
NetworkHostname: meteohub
Workgroup: HOME
MAC: 00:18:39:AA:27:D1
IP: 192.168.1.77
Gateway: 0.0.0.0
DNS: 192.168.1.1
WAN IP: no internet access
StorageSwap: 0MB of 127MB used (0%)
System: 213MB of 402MB used (52%)
Data: 33MB of 1322MB used (2%)
Date and TimeUTC: 18.10.2009 16:50:35
Time Zone: US/Mountain
Local Time: 18.10.2009 10:50:35
Uptime: 0 hours, 9 minutes
System Load: 0.42, 0.54, 0.35
ProcessWeather Data Recomputation: completed
Weather Data Logging: running (last data: 2 sec)
Weather Underground "Rapid Fire": running
SSH Login: running
SMB Shares: running
Time Synchonization: running
Info from system page
MeteoHub Network
10:52 18.10.2009
System Info
Network
Log Files
Inspect Data
Sensors
Settings
Weather Station
Dashboard
WD Live
Maintenance
Define Graphs
Manage Graphs
Setup Push Services
Graph Uploads
Weather Networks
WSWIN Data Export
WD Data Export
License
LAN IP DHCP
Net Mask
Gateway
DNS1
Workgroup
Hostname (needs reboot)
Port
Dynamic DNSDYNDNS Service none dyndns.org
Domain
User
Password
Info from network page.
rune
Re:Internet access
Post by rune »
Looks like you don't get a Gateway IP (Default gateway) from your DHCP server. Solutions are:
1) Fix the DHCP server (It *should* give you a Default GW) and refresh Meteohub.
2) Give Meteohub a static IP with a correct Default Gateway.
By the looks of your IP settings then your Default Gateway is probably 192.168.1.1.
kerry645
Re:Internet access
Post by kerry645 »
Thanks I think that fixed it. I no longer get the No Internet Access message. I am now uploading to Weather Underground but I think it takes 24 hours for them to activate.
