Problems with nslu2
s52sk
Problems with nslu2
Post by s52sk »
After I download new firmvare and uploaded to Nslu2 then nslu2 dont recognised USB stick and could not made the connection over LAN. What should be wrong. Is there possibility to get back older version of firmvare?
oporo
Re:Problems with nslu2
Post by oporo »
I am from Spain and I have the same problem.
I uploaded the meteohub-firmware.2.3, and in the next step I connect the USB stick but the NSLU2 doesn't do anything.
Whan can I do?
At what step does your system behave differently from what is explained in the manual?
Renato
Post by Renato »
I am from france and I have the same problem with
NSLU 07/2009 manufactured.
Ping 192.168.1.77 is ok.
After many test reset ant use Ugutil for retore firmware but anything.
Can you help me ?
Looks like USB stick not setup correctly. Please follow steps in section 1.1.3 of the manual exactly and have a look at "physical disk" notice when using DiskImage.
Renato
Post by Renato »
yes ok for the procedure, but any led disk 1 and 2 is green when i connect USB
After many test, i think blocket or Brick mu NSLU2
I can just Ping 192.168.1.77 is ok
After any, imposible re flash firmware...
Problem in french distributo for find NSLU2.
End of production ??
May be another solution ?
Thank you very mutch
Renato
Post by Renato »
all is ok
I have make USB Meteohub stick image correcttly with windows XP (NO WINDOWS SEVEN aand DD for windows).
Neeraj123
Post by Neeraj123 »
I have just bought the NSLU2 unit. After going over install ... formatted a brand new disk ... Acomdata HS USB 2.0 ... 180 GB ... then nothing ...
Do not see the drive on my PC ... it has just gone dead ...
Prior to installing NSLU2 , I check the new hard drive and everything was perfect ... even copied some material on it ... everything was fine ...
If anybody would have a clue ...
spoetnik
Post by spoetnik »
Installed on a 180 GB disk?? I can give you a clue, read the install manual for the NSLU. Can be found in the download section
First of all, when you have done the firmware flashing of your NSLU2 with the Meteohub firmware 2.3 and your NSLU2 doesn't start up correctly with the USB stick you prepared, then you prepared the USB stick the wrong way. Believe me, there are hundreds of NSLU2 Meteohubs out there all setup by the procedure described in the manual. It is working!
Having recognized that you did something wrong, please read instruction in section 1.1.3 IN DETAIL. Don't think you can skip things or have to format the stick with any other tool or can use any other storage media... once you have setup a working stick as explained in the manual, you are free to experiment, but you are on your own with this. ok?
95% of USB stick setup errors are caused by not correctly using diskimage. As the manual explains you have to use the "Physical disk" mode. When you scroll down the disk selction pop-down menu, you will find the disks listed as physical disks. Select your disk there.
When using "dd" you have to make sure to copy to the raw disk (ala /dev/sdx) and not to the first partition (ala /dev/sdx1) that has been created in the factory or by your windows formatting tool or whatsoever. Meteohub image is not a partition but a raw disk containing a partition table and 3 partitions. To keep all that complexity away from you the manual exactly describes how to install. When you do something slightly different, you are out of luck.
I did spend quite some time in explaining each step very detailed in the manual. Please take your time to follow these steps.
